Question about OBD-2 Diagnostic 16-pin plug???
Banned
I'm missing the OBD-2 Diagnostic plug (located under the dash near the hood latch area) that the smog station plugs in to smog the vehicle. I was wondering where the OBD-2 diagnostic plug connects on the underdash harness. Does it plug in along with the SRS wiring? If anyone could show me a picture of their obd-2 diagnostic plug and where it leads into underneath the dash that would be awesome. For some reason, I am missing that piece and was wondering if it was connected to my SRS wiring which I removed. Any help would be appreciated. Thanks in advance.
BTW my car is 99-00 Civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1b18cR »</TD></TR><TR><TD CLASS="quote">No, I have not cut any wires from what I remember. </TD></TR></TABLE>
Doesn't really matter - you've got the schematic. Find ECU pin A21 and trace the wire to wherever it ends as it should end directly at the connector.
There is a direct connection FROM the ECU to the DLC. Now, if you don't see the DLC hanging around, then more than likely....
....this was incorrect.
Now, is there presently a wire in A21?
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">There is a direct connection FROM the ECU to the DLC. Now, if you don't see the DLC hanging around, then more than likely....
Now, is there presently a wire in A21?</TD></TR></TABLE>
I did not cut any wire, but I did take out all the SRS related things such as the SRS computer and I took out the heater core. I'm assuming maybe it was attached to one of those. Those wires were just clips and I didn't have to cut anything. I'll go check if I could see the A21 wire. In the mean time, do you have any actual picture where I could look at other than a diagram? Let me know.
Did you cut any wiring? It would seem you had to have since there is a direct connection from the ECU to the DLC plug.</TD></TR></TABLE>
that diagram is useless you fat cow
jaydm ferio
Dec 12, 2006 04:04 PM
