SoCal: Need Help w/Install Clutch/Flywheel
Old Nov 22, 2004 | 10:16 PM
JDEM1's Avatar
Default SoCal: Need Help w/Install Clutch/Flywheel
Hey guys, need someone in the socal area to help me install some parts, I searched for writeups, but it still looks too frustrating to try myself for the first time, so I need some help, here is the work needed to be done:
-Act XT/SS clutch install
-Act Flywheel install
-SS braided clutch line install
-Oem Rear main seal? (I hear you should replace this)
-Change tranny fluid
and that's about it, located in O.C. Ca, I will pay for help, and if someone can just do the complete job for cheap, that would be good as well
The past couple of times I had my clutch installed, I had bad experiences.. the pedal felt weird, and strange noises coming from the clutch still, i believe it is a bad throwout bearing?, anyhow, very experienced help is greatly appreciated
ahhh.. btw.. this is for my 00 civic si
Old Nov 22, 2004 | 10:18 PM
civictildeath's Avatar
Default Re: SoCal: Need Help w/Install Clutch/Flywheel (JDEM1)
look up luserkid
Old Nov 22, 2004 | 10:26 PM
JDEM1's Avatar
Default Re: SoCal: Need Help w/Install Clutch/Flywheel (civictildeath)
thanks, PM'd him, anyone else?
Old Nov 22, 2004 | 11:38 PM
backdraft's Avatar
you can hit me up.... We at DOHC garage can do it for you. Either hit me up here or you got my # on the bottom of my signature. Thanks, Scott
boostin92hatch
Apr 15, 2006 09:15 AM
Pompiuses
Apr 18, 2005 06:42 AM
aesthetics82
Jun 10, 2003 08:57 PM
civEX
Apr 21, 2002 06:10 PM
