86 crx si
Old Nov 22, 2004 | 09:14 PM
89POS's Avatar
Default 86 crx si
what are/if any swap options for this car? from easiest to hardest. is it possible to turbo? i saw pgfi on the engine so im assuming its running the same fuel injection as the 88-91 dx/stds?
should i just quit b4 i begin?
Old Nov 22, 2004 | 09:50 PM
KFBhonda's Avatar
Default Re: 86 crx si (89POS)
any engine is "possible" to turbo, but would you want to bother is sometimes the real question.
hasport used to make mounts for b-series into the 3rd generation civics/1st-gen CRX's but have discontinued them. but you could possibly find some still around, maybe used but they have a lifetime guarantee.
Old Nov 22, 2004 | 10:18 PM
tur3oDC4's Avatar
Default Re: 86 crx si (KFBhonda)
Dont bother putting a motor into it untill you blow up your si. Thats why you need a turbo. I built my turbo kit for my 88 si for about a grand. You can get shity parts and get it boosting for like $300-$400ish. Search around for "HMT" "Home Made Turbo" you'll like what you see.
Old Nov 23, 2004 | 01:54 AM
mrspeaker's Avatar
Default Re: 86 crx si (B18CRXjake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89POS &raquo;</TD></TR><TR><TD CLASS="quote">what are/if any swap options for this car? from easiest to hardest. is it possible to turbo? i saw pgfi on the engine so im assuming its running the same fuel injection as the 88-91 dx/stds?
should i just quit b4 i begin?</TD></TR></TABLE>
That motor has mpfi with just like the 88-91si's..
87-89 integra motor bolts in the 84-87civic/crx..
Old Nov 23, 2004 | 11:28 AM
dr_latino999's Avatar
Default Re: 86 crx si (Mrspeaker)
http://www.redpepperracing.com
Old Nov 23, 2004 | 07:42 PM
89POS's Avatar
if i were to use the integra motor, do i use the crx tranny or the integra tranny??does the teg tranny bolt in?
does the intake mani. off the crx bolt to the teg engine?
will the teg engine just plug in or will i have to cut-n-paste the harness?
how is the suspension for this year and is there an aftermarket?
THANX TO EVERYONE WHO TOOK A MINUTE TO HELP.
Old Nov 23, 2004 | 07:54 PM
jlicrx's Avatar
use the 86-87 Integra engine which is more compatible with your car - use engine, transmission, ECU, axles, knuckles/hubs and shift linkage from the Integra - all bolts right in - wiring harness plugs right in to all connectors, except at the distributor due to Cylinder Position Sensor on exhaust camshaft - 88-89 Integra will work, just more wiring issues - CRX intake manifold will not fit D16A1
Old Nov 24, 2004 | 06:43 AM
whizzlefist's Avatar
f<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89POS &raquo;</TD></TR><TR><TD CLASS="quote">if i were to use the integra motor, do i use the crx tranny or the integra tranny??does the teg tranny bolt in?
THANX TO EVERYONE WHO TOOK A MINUTE TO HELP.</TD></TR></TABLE>
hey you need to go to Red pepper racing now. this site cant compare to the info we have in f the FAQ http://www.redpepperracing.com
and the stock si motor is a great motor you may want oto consider that engine before a swap
Old Nov 24, 2004 | 07:19 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: 86 crx si (whizzlefist)
i love my D15A3, it is a great engine to FI IMO.
sift through the posts at redpepperracing and you will find a lot of info, marcus, who is a member of both HT and RPR has an inspirational CRX
stan
Old Nov 25, 2004 | 09:18 AM
tur3oDC4's Avatar
Default Re: 86 crx si (Stan D)
turbo
asheppo7
Oct 17, 2010 02:52 PM
Hi_Boost
Dec 19, 2006 01:20 AM
DrPhang
May 14, 2002 09:09 PM
Teluan
Sep 5, 2001 04:53 AM
