Upgrading from CX brakes to EX brakes...
Old Nov 22, 2004 | 09:03 PM
AThiker's Avatar
Default Upgrading from CX brakes to EX brakes...
I've got a 92 civic CX and I'm upgrading my brakes to 95 civic EX brakes - knuckles, rotors, calipers, booster, MC, prop valve. Is this a straight bolt-up upgrade or am I going to need to bend or reflare any hard lines? If yes, which ones will I need to bend or reflare?
TIA
Old Nov 23, 2004 | 08:45 AM
AThiker's Avatar
Default Re: Upgrading from CX brakes to EX brakes... (jgop_151)
Old Nov 23, 2004 | 08:49 AM
slambedcivic's Avatar
straight bolt on. i dont think youll need the prop valve and all of that, i believe its all the same. all you need is the spindles/hubs, and rear drum setup.
Old Nov 23, 2004 | 09:54 AM
pdiggitydogg's Avatar
straight bolt on
no, you dont need the prop valve, just knuckles, rotors, and calipers...mc/bb if you want it.
I have a set of calipers, rotors, and pads for sale right now (pretty damn cheap imo)
Old Nov 23, 2004 | 10:02 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (pdiggitydogg)
Use the proper Master Cylinder when upgrading front brakes (you will like them better). The EX Master Cylinder is a 7/8ths unit. If you are going to upgrade to rear discs in the future, you may want a 15/16th unit from the 91 Civic EX 4door.
I do believe all the brake boosters are the same for all 92-95 civics though, so if your curent one works fine, you may just want to leave it in. I could be wrong, but a quick part number check on http://www.hondaautomotiveparts.com will confirm.
Use the proper Proportioning valve when upgrading your rear brakes (will be much safer).
boarding2008
Aug 27, 2012 05:11 AM
Turbo_Mike
Jun 22, 2008 05:53 AM
VTEC-in_Beaver
Feb 10, 2008 07:15 AM
goforbroke
May 5, 2006 11:45 AM
vegan_punk
Feb 16, 2003 10:45 AM
