obd0 to obd1
Old Nov 22, 2004 | 07:29 PM
crazyslowhatch's Avatar
Default obd0 to obd1
alright, i'v got a d15y8 minime and an running just a obd0 si ecu as if right now.. my friend just gave me a p28 ecu, a obd1 dizzy, and pigtails for the obd0 to obd1 ecu.. is this everything thing i need to run the p28 ecu? if not what else do i need and if so what all needs to be done to make this work? like wiring and what not
Old Nov 22, 2004 | 07:39 PM
Default Re: obd0 to obd1 (crazyslowhatch)
Old Nov 22, 2004 | 07:44 PM
eda6's Avatar
Get a 4 wire o2 sensor
Old Nov 22, 2004 | 07:50 PM
mannyman's Avatar
El Veterano de Sur Califas
you will need to wire up a 4 wire 02 sensor, wire up a knock sensor, repin the stock distributer harness match the 0bd1 dizzy. hook up the vtec wires, if you havnt already did so. wire up a toggle switch to check for codes. I think thats most of it, if I forgot something, im sure someone will mention it. goodluck
manny
Old Nov 22, 2004 | 07:58 PM
eda6's Avatar
Default Re: obd0 to obd1 (mannyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mannyman &raquo;</TD></TR><TR><TD CLASS="quote">you will need to wire up a 4 wire 02 sensor, wire up a knock sensor, repin the stock distributer harness match the 0bd1 dizzy. hook up the vtec wires, if you havnt already did so. wire up a toggle switch to check for codes. I think thats most of it, if I forgot something, im sure someone will mention it. goodluck
manny</TD></TR></TABLE>
p28 doesn't look for a knock sensor. Don't worry about that.
Old Nov 22, 2004 | 08:26 PM
Default Re: obd0 to obd1 (eda6)
thanks guys, is the wiring hard? does anyone know where i can get a wiring diagram to convert the 0bd1 dizzy?
Old Nov 23, 2004 | 06:41 PM
on the pig tails i got (they are used) have some wires that have been pulled out.. anyone have a wiring diagram for them and for the dizzy? pig tails is what i'm mostly worried about, any help?
Old Nov 23, 2004 | 06:58 PM
iphatcrxi's Avatar
i have a d16a6 mini me, im trying to stay obd0, which ecu would you recommend, pr3, pw0, or pg7?
Old Nov 23, 2004 | 07:01 PM
Default Re: obd0 to obd1 (iphatcrxi)
right now i'm just running a pm6 with vtec on a switch
Old Nov 23, 2004 | 07:03 PM
iphatcrxi's Avatar
lol, ghetto
Old Nov 23, 2004 | 07:04 PM
iphatcrxi's Avatar
yea my car is an Si, i have a pm6 but i need an ecu that will activate vtec
Old Nov 23, 2004 | 07:22 PM
mengo_charged's Avatar
Sorry to steal the thread, but I didn't want to make another one...it still stays on topic though! So does anyone know how to make an obd-2 d-series dizzy turn into obd-1? Asking because I want to obd-1 my d16a6 w/a d15b7 ecu (since the obd-1 dizzy's don't fit) for Hondata.
Old Nov 23, 2004 | 07:24 PM
iphatcrxi's Avatar
Default Re: obd0 to obd1 (mengo_charged)
they make obd-2 for d series?
Old Nov 23, 2004 | 07:47 PM
96-EJ6 B18C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mengo_charged &raquo;</TD></TR><TR><TD CLASS="quote">(since the obd-1 dizzy's don't fit) for Hondata.</TD></TR></TABLE>
???? I have one on my A6 and I didn't have to mod it at all (besides the plug).
For the original question...you'll need an OBDI distributor, OBDI ECU, Jumper harness, and a 4 wire o2 sensor.
Old Nov 23, 2004 | 07:49 PM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iphatcrxi &raquo;</TD></TR><TR><TD CLASS="quote">they make obd-2 for d series?</TD></TR></TABLE>
Yes. the 96+ D16Y8 are OBD-II. I installed a D16Y8 into my old car, and used the distributor from that engine. It is the same wiring as OBD-I; the only thing is, the plugs are different. So the answer is yes, you can use an OBD-II distributor with an OBD-I ECU.
Old Nov 23, 2004 | 08:09 PM
Default Re: obd0 to obd1 (Mr. S)
pig tail wiring diagrams anyone?
Old Nov 23, 2004 | 08:10 PM
iphatcrxi's Avatar
i think im going to buy a pw0 or pr3 ecu from an obd0 b16, think that would work?
Old Nov 23, 2004 | 08:29 PM
mr. carpenter's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyslowhatch &raquo;</TD></TR><TR><TD CLASS="quote">pig tail wiring diagrams anyone?</TD></TR></TABLE>
try seraching p28 pinouts.
Old Nov 23, 2004 | 08:30 PM
Default Re: obd0 to obd1 (mr. carpenter)
found this.
http://www.hondaswap.com/forum...29360
Old Nov 23, 2004 | 08:33 PM
Is there a difference between a Y8 dizzy and a Y7 dizzy? Which one would I use to convert my d16a6 to obd-1?
Old Nov 23, 2004 | 08:56 PM
thanks for the site
Old Nov 23, 2004 | 08:59 PM
hope it helps. there were some other results in the search that was just the first one.
Old Nov 23, 2004 | 09:09 PM
what did you search for? i tryed more then once but i most not of been searching for the right topic.. thanks agin!
Old Nov 23, 2004 | 09:11 PM
p28 pin outs. search archived posts. here's another. i think the p28 and p30 are basically the same.
http://tech2.hybridgarage.com/..._obd1
USDM sI
Sep 13, 2010 03:20 PM
ef-hatchcrap
13
May 18, 2008 12:01 PM
hatchyboy89
Apr 5, 2005 10:20 AM
JusT a Cx
14
Apr 28, 2004 09:17 AM
scdarksol
14
Nov 16, 2003 06:26 PM
