k20a2 swap in 99 ek... what ecu???
Old Nov 22, 2004 | 07:19 PM
ensracer's Avatar
Default k20a2 swap in 99 ek... what ecu???
wondering what ecu i can run with this swap.... any vtec one that plugs in or does it have to be a k20 one... also is there a thread about the wiring that must be done... thank you
Old Nov 22, 2004 | 07:31 PM
TypeR0186's Avatar
Default Re: k20a2 swap in 99 ek... what ecu??? (ensracer)
jdm k20a or send the usdm k20ecu to hondata or get k-pro.....
Old Nov 26, 2004 | 01:42 PM
99lsvtecauto's Avatar
Default Re: k20a2 swap in 99 ek... what ecu??? (TypeR0186)
what he said no old school ecu will work properly
Old Nov 27, 2004 | 08:52 AM
Goatsterrman's Avatar
Default Re: k20a2 swap in 99 ek... what ecu??? (99lsvtecauto)
No B, D, H series ECU will work. You will need a K-series. A USDM K20a2 ecu will not crank the car do to immobilizer issues. A JDM K20a ECU will work after bypassing the immobilizer. I highly recommend the K-pro from Hondata. Great Tuning tool and will eliminate the USDM immobilizer so the USDM ECU can be used.
Revi
Oct 11, 2006 03:15 PM
MyEvo8GotRepo
Jul 18, 2005 11:57 AM
Duck Sauce
Dec 12, 2001 01:58 PM
