Better to go k20a or k24 for all motor?
Old Nov 22, 2004 | 06:52 PM
b16civic91's Avatar
Default Better to go k20a or k24 for all motor?
I want to have one bad *** all motor. Aiming 250+ to the wheels. What do you recommend for parts and motor.
Old Nov 22, 2004 | 10:07 PM
dmotoguy's Avatar
Default Re: Better to go k20a or k24 for all motor? (b16civic91)
k20a2 or k20a, i/h/e, maybe cams and tune it with whichever ecu you wanna get
Old Nov 22, 2004 | 10:42 PM
JDMotive's Avatar
I'd go with a K20a if I were you.The K24 would require you to build it up to be able to get the power and rev's from it,while the K20 can do it on a stock bottom end.The stroke of the k24 is just too big to be a long lasting engine when revved high.
Old Nov 23, 2004 | 11:01 AM
Professor15's Avatar
Default Re: Better to go k20a or k24 for all motor? (JDMotive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMotive &raquo;</TD></TR><TR><TD CLASS="quote">I'd go with a K20a if I were you.The K24 would require you to build it up to be able to get the power and rev's from it,while the K20 can do it on a stock bottom end.The stroke of the k24 is just too big to be a long lasting engine when revved high.
</TD></TR></TABLE> Why would you want to rev it up that high if you werent making power that high? Wouldnt keeping the power under the blocks revving limitation be better way of using the block? The k24 has alot of potential
Old Nov 23, 2004 | 11:05 AM
justBLZE's Avatar
Chopper 2 Hopper
If you want to have a bad *** motor definetly K24, you know, that whole displacement thing is under rated
Be ready for some big buck spending...
Old Nov 23, 2004 | 11:11 AM
JerseySiPOS's Avatar
Default Re: Better to go k20a or k24 for all motor? (tommy69)
For your goal, go K20a2 or K20a. You have enough compression for possibly bigger cams, on top of being able to extract so much power from the motor with just bolt ons and tuning.
i dont see the purpose and logic in throwing in such a long stroke block when you have to build it for reliable. And your goal doesnt require that.
Go with a wider powerband and i would always go with a bigger bore before a longer stroke.
Til this day, i dont understand how ppl dont see that most of the power comes from the head.
More displacement is not always the answer.
Modified by JerseySiPOS at 8:23 PM 11/23/2004
Old Nov 23, 2004 | 11:37 AM
FOrSfEd's Avatar
Default Re: Better to go k20a or k24 for all motor? (JerseySiPOS)
k24 built bottom, k20a head. Basic bolt ons and a good tune. Easy 250+++++
Old Nov 23, 2004 | 12:10 PM
aznboysrfr's Avatar
go k24. mad torque
http://forums.clubrsx.com/showthread.php?t=211801
Old Nov 23, 2004 | 02:29 PM
JDMotive's Avatar
Default Re: Better to go k20a or k24 for all motor? (drchulo)
If you werent making power that high than you wouldnt need it to rev that high,but the K20 does make power up high and wouldnt require a build to make good power.The K24 has a weak bottom end in stock form and would need the build to make good power.The stroke of the K24 is too big in my opinion for a reliable race car.If you wanted to make good power you would need big cams which would require more rev's which the K24 cant handle and would wear out sooner even when built.The K24 does make really good torque though.
Old Nov 23, 2004 | 02:34 PM
97L-esVeeTeg's Avatar
Default Re: Better to go k20a or k24 for all motor? (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">k24 built bottom, k20a head. Basic bolt ons and a good tune. Easy 250+++++</TD></TR></TABLE>
next gen frankenstein is always a interesting choice, skunk2 has made great power with this setup, but im not sure if they are using it in their race car, i would look into it, hell if i had the money i'd give it a try
Old Nov 23, 2004 | 10:56 PM
dmotoguy's Avatar
Default Re: Better to go k20a or k24 for all motor? (97L-esVeeTeg)
k20a2 :
Old Nov 23, 2004 | 11:53 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Better to go k20a or k24 for all motor? (dmoto)
Old Nov 24, 2004 | 12:05 AM
EMO-anthony's Avatar
Damn nice stuff!
Old Nov 25, 2004 | 12:14 PM
sloboy_joe's Avatar
Default Re: Better to go k20a or k24 for all motor? (THAiGuYDc2)
go k24 bottom end for torque and k20 head, if you can afford k-pro go for it also toda head package and you'll be very fast!!!!!!
Old Nov 25, 2004 | 12:34 PM
dmotoguy's Avatar
Default Re: Better to go k20a or k24 for all motor? (sloboy_joe)
why not just keep the k20.. you'll have enough torque with it.
Old Nov 25, 2004 | 02:55 PM
sloboy_joe's Avatar
true but u said you wanted a bad *** motor k24 bottom end would be more power
Old Nov 25, 2004 | 04:49 PM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloboy_joe &raquo;</TD></TR><TR><TD CLASS="quote">true but u said you wanted a bad *** motor k24 bottom end would be more power</TD></TR></TABLE>
Im still new to the whole k-series motor thing and I am thinking of getting one to put in a EH Hatch!
Is it true that the bore on K24 is 87mm and the stroke is 99mm?
i am thinking K24 just b/c I am one of those non-vtec ******** and 99mm's of stroke sounds like there is some potential power to be made!
Old Nov 26, 2004 | 04:10 AM
6SPD_EK's Avatar
Default Re: Better to go k20a or k24 for all motor? (hybrid_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">
i am thinking K24 just b/c I am one of those non-vtec ******** and 99mm's of stroke sounds like there is some potential power to be made!</TD></TR></TABLE>
yes stock bore is 87mm.... one thing you forget about the stroke of 99mm - when combined with stock rod length (153mm) makes for incredibly high piston speeds which can KILL reliability & power at high revs
Old Nov 26, 2004 | 06:06 AM
Default Re: Better to go k20a or k24 for all motor? (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR &raquo;</TD></TR><TR><TD CLASS="quote">
yes stock bore is 87mm.... one thing you forget about the stroke of 99mm - when combined with stock rod length (153mm) makes for incredibly high piston speeds which can KILL reliability & power at high revs</TD></TR></TABLE>
Dont plan on reving high! I'll more than likely make power at lower than 8K just like other nonvtecs! What is its factory redline and factory specs?
Old Nov 26, 2004 | 12:02 PM
PirateMcFred's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR &raquo;</TD></TR><TR><TD CLASS="quote">One thing you forget about the stroke of 99mm - when combined with stock rod length (153mm) makes for incredibly high piston speeds which can KILL reliability & power at high revs</TD></TR></TABLE>
Well that is only 1.55 RS ratio. That is better than the LS/B20VTEC's 1.54 and they spin those to 8K all day long. I would still stick with the K24A2 with swapped pistons/IM. They are only $1300 on http://www.car-part.com
Pirate
Old Nov 26, 2004 | 02:31 PM
top_secret's Avatar
Default Re: Better to go k20a or k24 for all motor? (PirateMcFred)
If you have the money Go with a K24 block
Old Nov 26, 2004 | 03:10 PM
Aquafina's Avatar
Default Re: Better to go k20a or k24 for all motor? (top_secret)
A lot of the road racing guys are going from the K series back to the B series. Though this is on a stock bottom end, they said the rod bolts are failing very shortly after a mis-shift. No personal experience with this so you might want to search in the RR/AX forum.
Old Nov 26, 2004 | 03:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by top_secret &raquo;</TD></TR><TR><TD CLASS="quote">If you have the money Go with a K24 block </TD></TR></TABLE>
I want the the whole K24 and run nonvtec! Where can I get one?
Old Nov 27, 2004 | 07:18 PM
Nikos's Avatar
you can get one from larry Jr at http://www.importautosalvage.com
Tell him Nikos , sent you
Good luck
Old Nov 27, 2004 | 07:31 PM
Default Re: Better to go k20a or k24 for all motor? (Nikos)
Thanx!
Circuit Star-29
May 17, 2006 10:24 PM
K20Ej1
11
Feb 3, 2006 06:07 AM
civiccoupe94
12
Sep 26, 2005 03:59 PM
PGT Driver
24
May 12, 2005 08:01 PM
Filliam H. Muffman
16
Jan 1, 2004 08:19 PM
