Wiring for Fuel injection Custom
Old Nov 22, 2004 | 05:39 PM
Tex Blackwell's Avatar
Default Wiring for Fuel injection Custom
I understand how to wire up the signal for the injectors but as for the negatives, i see on a wiring diagram that they go to "JUNCTION CONN C125".
also, connected to that is the negative for the:
-Purge control
-Elect air control valve
-PGM-FI Main relay
eventually it all ends up connecting to IGP connection A25 on the ecu
before the wire actually reaches the ecu it goes through a "12" little square, not sure if that is a fuse or what.
Basically i'm rewiring all the fuel injection parts to have a cleaner look.
is the "junction conn" just making all the wires touch each other to basically make one ground?
menthos
Engine Management and Tuning
16
Sep 16, 2008 07:51 AM
RIZOBIZERT
Feb 28, 2008 12:25 PM
hotinteggy
Mar 13, 2005 09:36 AM
Tex Blackwell
Nov 24, 2004 07:35 AM
