90 in an 89??? help please asap!!!!!
Old Nov 22, 2004 | 05:20 PM
wcp prelude's Avatar
Default 90 in an 89??? help please asap!!!!!
i have a chance to buy a 90 prelude 2.0 si tranny...will it fit on my 89 2.0 si motor??? thanks for any help!!!!!!
Old Nov 22, 2004 | 11:40 PM
car_boy_16's Avatar
Default Re: 90 in an 89??? help please asap!!!!! (wcp prelude)
Yea It will fit, is it auto or stick? If it's stick, then you will have to change the clutch disc, pressureplate, and flywheel to the 90-91 style.
The clutch systems changed 90, so 88-89 and 90-91 are the two different designs. You will also have to ask around about the VSS (Vehicle Speed Sensor) conversion/swap, the 88-89 VSS has a cable leading to the gauge cluster from the tranny and the 90-91 VSS is electronic which eliminates that cable.
For more info, check out http://www.preludepower.com and search around on there before you ask any questions, it's been covered many times! Good luck.
jcharron121
Dec 8, 2011 07:25 AM
SIsohcvtec
Aug 30, 2004 06:23 AM
DualCamDan
Feb 21, 2004 06:25 AM
V3locity
Jan 18, 2004 08:51 PM
Escabar
Jan 8, 2004 10:00 AM
