DA integra knuckles question...
Old Nov 22, 2004 | 05:11 PM
crexer's Avatar
Default DA integra knuckles question...
Im having a hard time finding a set of 90-91 ex knuckles and we all know 90-93 integra knuckles are easy to come by and are cheaper. My question is will the integra knuckles fit onto dx axles? Are the splines the same?? Im gettin ready to do a b16 swap pretty soon but i was wanting to go ahead and get my brakes in line. Also Is there a difference between the Integra knuckes ( ls gs or gsr? 4 door or hatch???
Old Nov 22, 2004 | 05:24 PM
Loaded Butane's Avatar
Default Re: DA integra knuckles question... (crexer)
I know the axles will work fine but am not sure about the rest. I am in the process of researching that swap myself.
Old Nov 22, 2004 | 05:27 PM
keithg's Avatar
I just bought a pair of 90-91 Civic EX knuckles off of http://www.car-part.com for $100 for the pair. I have used the 90-93 Integra knuckles on an EF in the past and I can't remember why I didn't like it.
The 90-93 Integra splines are the same as the 88-91 Civic/CRX, DX/SI knuckles. The only difference in the 90-93 Integra knuckles between the different trim levels is with or without ABS, and that doesn't matter for what you are doing.
Old Nov 22, 2004 | 05:43 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
you can use DA knuckles, the important thing to remember is to retain the stock upper control arms. the spline count is the same and your swap will work with no issues.
stan
Old Nov 22, 2004 | 06:19 PM
EL Vap133's Avatar
There is no difference in the knuckles for the DA, between ls, gs, 4dr.
Old Nov 22, 2004 | 06:58 PM
JapJunkie's Avatar
Default Re: DA integra knuckles question... (Stan D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D &raquo;</TD></TR><TR><TD CLASS="quote">you can use DA knuckles, the important thing to remember is to retain the stock upper control arms. the spline count is the same and your swap will work with no issues.
stan</TD></TR></TABLE>
wats the point to keeping the stock upper CAs?
I have DA front knuckles and just swapped it over complete, didnt take anything off or on .
Old Nov 22, 2004 | 07:00 PM
jhota's Avatar
Default Re: DA integra knuckles question... (keithg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithg &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a pair of 90-91 Civic EX knuckles off of http://www.car-part.com for $100 for the pair. I have used the 90-93 Integra knuckles on an EF in the past and I can't remember why I didn't like it.
The 90-93 Integra splines are the same as the 88-91 Civic/CRX, DX/SI knuckles. The only difference in the 90-93 Integra knuckles between the different trim levels is with or without ABS, and that doesn't matter for what you are doing.</TD></TR></TABLE>
sweet link dude, thx!
Old Nov 22, 2004 | 08:33 PM
Putput's Avatar
Default Re: DA integra knuckles question... (jhota)
Some posted that if you use Integra DA knuckles your geometric and your alignment will always be off. Here's a link...
http://tjshondas.20m.com/xlfronts.htm
"*90+ Integra steering knuckles ARE different from 88-91 Civic/CRX knuckles. Their shape and size will affect all three alignment settings (camber, caster, and toe). The camber will go positive (+), the caster will go negative (-), and the toe will need to be reset since the tie rod end location is in a different place on the Integra units. There are ways of correcting both the camber and caster, but the overall height of the knuckle may cause your upper control arm to hit the underbody on lowered cars."
Old Nov 22, 2004 | 08:36 PM
JapJunkie's Avatar
Default Re: DA integra knuckles question... (Putput)
ohh okay i get it, see i think i might have that problem...
Old Mar 3, 2021 | 10:20 AM
Vonhadengage's Avatar
stan
Why is it important to keep your stock upper control arms?
Old Mar 3, 2021 | 10:59 AM
Tyson's Avatar
DA upper control arms dont fit. dont work. wont even bolt up.
i wouldnt say its "important", i think its just a warning dont bother going out of your way to get a DA upper control arm.
Old Mar 3, 2021 | 01:45 PM
Canadian_EF's Avatar
Instead of using DA knuckles, you can convert to 10.3" brakes on the stock Civic DX knuckles. It is an option.
ja20_eg
Oct 3, 2008 05:45 AM
Dateggy21
Aug 11, 2008 06:35 PM
T S R Performance
Feb 19, 2007 12:13 PM
