upgrading brakes with OEM
Old Nov 22, 2004 | 04:49 PM
crxdx89's Avatar
Default upgrading brakes with OEM
what is the biggest rotor upgrade for a crx with steelies with OEM honda rotors, keeping the stock crx knuckles, calipers etc etc....
Old Nov 22, 2004 | 04:59 PM
crexer's Avatar
Default Re: upgrading brakes with OEM (crxdx89)
dosent sound like to much of an "upgrade" if you wanna keep alll your stock stuff. Bigger is not always better, especially if you are not upgrading things like the MC, and prop. valve. Just get a good set of slotted rotors and some nice pads.
Old Nov 22, 2004 | 05:10 PM
rice_classic's Avatar
Default Re: upgrading brakes with OEM (crexer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">dosent sound like to much of an "upgrade" if you wanna keep alll your stock stuff. Bigger is not always better, especially if you are not upgrading things like the MC, and prop. valve. Just get a good set of slotted rotors and some nice pads.</TD></TR></TABLE>
He's right (except for the slotted rotor comment).
Unless you upgrade the caliper/pad there is no benefit in upgrading the rotor because you will still have the same heat buildup in the caliper/pad.
You're best bet is to upgrade rotor/caliper together. You can do the 10.3 civic ex upgrade or you can do what I did and get the fast brakes kit which is an 11" rotor with Integra Calipers. I've used this setup on MANY of track days and not once did I have to worry about my brakes.
Old Nov 22, 2004 | 05:14 PM
crexer's Avatar
Default Re: upgrading brakes with OEM (rice_classic)
well that totally strays away from his original need but whats wrong with slotted rotors???
Old Nov 22, 2004 | 05:29 PM
drdisco69's Avatar
Well the answer is you can't go any larger without replacing the calipers. Better pads go a LONG way in making the brakes better, it's really amazing. I still hate stock honda brakes and my weenie rotors, so 11.1" rotors are in my future.
Old Nov 22, 2004 | 05:35 PM
krazie1's Avatar
BANNED
Default Re: upgrading brakes with OEM (drdisco69)
I totally agree
Old Nov 22, 2004 | 05:46 PM
keithg's Avatar
I think that the 92-5 Civic DX rotors are the same diameter but THICKER (14mm v.s. 12mm???) than the 88-91 rotors. Also, I think http://www.fastbrakes.com offers a bigger diameter oem rotor and caliper brackets for your car so you can keep the stock calipers but use a bigger diameter oem rotor. Email the fastbrakes guy, he knows all the options. You would have to "space out" your stock caliper to use a larger diameter rotor.
Old Nov 22, 2004 | 10:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">well that totally strays away from his original need but whats wrong with slotted rotors??? </TD></TR></TABLE>
I have them on my car so I shouldn't talk smack but with todays technology in brake pads there's just no need. The more surface your pad touches the more friction it encounters, also you can find many people that will say slotted rotors are only good for eating up pads (and most of these people have been racing cars for years).
Feel free to ask around though, make sure to ask the people who use them in an actual "road racing application"... if you can find any. They cost more and don't improve anything therefore where performance meets cost-effectiveness you are at a loss.
They are for show... like on my car! I have big, 11" slotted rotors on my crx cuz it's blingin' yo!
Old Nov 23, 2004 | 12:35 AM
Rostr02's Avatar
I have slotted rotors too although i have not got the change to road race my car at all this year due to engine problems with the zc so . . . time for a k series
Old Nov 23, 2004 | 05:45 AM
crx_88_si's Avatar
just get some good brembo blanks, some hawk hp+ pads and good brake fluid. bleed the heck out of it and you'll be a happy camper.
and GET ss brake lines.
Old Nov 23, 2004 | 05:46 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdx89 &raquo;</TD></TR><TR><TD CLASS="quote">what is the biggest rotor upgrade for a crx with steelies with OEM honda rotors, keeping the stock crx knuckles, calipers etc etc....
by NOT changing those (or spending bling on fastbrakes) just do what i said above.
Old Nov 23, 2004 | 06:43 AM
SqueezinEF's Avatar
Default Re: upgrading brakes with OEM (crx_88_si)
I have slotted/drilled rotors all around. I hate it. I am waiting for some DA front knuckles to come around. Then I will change it all to blanks with nice pads. Slotted are good only for looks. Great pads are a better upgrade.
Old Nov 23, 2004 | 04:14 PM
crexer's Avatar
Default Re: upgrading brakes with OEM (SqueezinEF)
why do you "hate" your slotted rotors? I have slotted brembos and aem ceramic pads for goin on 2 years and they have plenty of meat left. Dosent the slot on the rotor refresh the pad and keep buildup from forming between the pad and rotor causing squeeks? You guys keep talking about road race applications and stuff like that but the original poster said nothing about road racing or extreme braking components.
Old Nov 23, 2004 | 04:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">why do you "hate" your slotted rotors? I have slotted brembos and aem ceramic pads for goin on 2 years and they have plenty of meat left. Dosent the slot on the rotor refresh the pad and keep buildup from forming between the pad and rotor causing squeeks? You guys keep talking about road race applications and stuff like that but the original poster said nothing about road racing or extreme braking components.</TD></TR></TABLE>
You're right that he doesn't need to worry about road racing applications but in a case where slotted rotors might cost more then blank rotors, he should go with blanks. Slotted rotors don't increase the life of your pads. Slotted rotos also don't last as long because since the rotor now has an inconsistency (slots) in the surface it will be more prone to develop cracks and that could ultimately require them to be replaced earlier then say, a blank rotor.
This is just a lot of really uselss info because you're not racing and you're not spending 150$ on pads so you don't have to worry about either one. If you want the look of slotted rotors (like us fast brakes users have) then go for it. I don't think there is anything wrong with them... they just aren't a "performance increaser" by any means. Just want that information to be clear.
Information needs to be displayed on the information super highway.
Old Nov 23, 2004 | 05:34 PM
cursED's Avatar
If you go with the EX knuckles, the 94+ Integra calipers & rotors bolt up with no machining necessary. This combination will fit under Honda factory 14" steel wheels. More than enough braking for the track, if you want to go there.
IMO, 11.1" upgrade is a lot of extra weight, and requires 15" wheels.
If you want to use your stock calipers, contact FASTBRAKES, as mentioned by user keithg above.
Old Nov 26, 2004 | 12:04 PM
Nov!ce's Avatar
Where did you get/buy your kit? How much, if you don't mind telling?
Old Nov 26, 2004 | 12:16 PM
Nov!ce's Avatar
Default Re: upgrading brakes with OEM (cursED)
When you say "EX knuckles" are you referring to an EG?
Old Nov 26, 2004 | 12:33 PM
Riceburner247's Avatar
Default Re: upgrading brakes with OEM (Nov!ce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nov!ce &raquo;</TD></TR><TR><TD CLASS="quote">When you say "EX knuckles" are you referring to an EG?</TD></TR></TABLE>
90-91 civic 4dr EX.
Old Nov 26, 2004 | 09:12 PM
cursED's Avatar
Default Re: upgrading brakes with OEM (riceburner247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">
90-91 civic 4dr EX.</TD></TR></TABLE>
Yes, that is correct. You must use the 90-91 civic 4dr EX knuckles as stated above to physically mount the 94+ Integra calipers & rotors. Again, no machining is necessary.
iperez
Oct 14, 2006 11:24 AM
Type - ARman
May 9, 2005 08:53 PM
Abshonda
Mar 23, 2004 05:15 PM
Accorddrver
Jul 24, 2003 05:32 PM
Alexander
Oct 5, 2002 12:25 PM
