OIL PAN
Old Nov 22, 2004 | 04:24 PM
eRACING's Avatar
Default OIL PAN
Anyone know if theres any differences between the b16 (PR3 oil pan) and the the b18 (P72 oil pan)?? Are they both identical, or have different depths? will a B16 oil pan work on a GSR block? or GSR oil pan work on a B16?
Old Nov 22, 2004 | 07:29 PM
mmuller's Avatar
Mad Scientist
Default Re: OIL PAN (erics99si)
they are different and will not interchange unless you use the corresponding hardware.
non- vtec b's and pr3 are the same though
Old Nov 23, 2004 | 03:46 AM
eRACING's Avatar
Default Re: OIL PAN (mmuller)
anyone?? I've heard that the b16 pan will fit on the b18 motor if you're not using a crank girdle, and the b18 pan will fit on the b16 whether you have the girdle or not.. Can anyone confirm this?
DelSol-B18
Sep 21, 2012 04:57 AM
JDMCIVIC919
Jan 26, 2012 10:12 AM
precisionsc54
May 6, 2011 03:38 PM
curiousgpnoy
22
Jan 29, 2003 08:00 AM
