Cannont get amp to work!!! pissing me off!!
Old Nov 22, 2004 | 04:19 PM
Myh4tch's Avatar
Default Cannont get amp to work!!! pissing me off!!
So I hookup my new alpine deck (9831) and i have a pioneer 12" sub and Rockford Fosgate Amp (punch something) and i have the power going to "B+" on the amp, Ground is grounded in the bottom where the spare goes and connected to "GND" on amp, i have the positive wire from the sub run to (+) on amp and Neg on sub running to (-) on amp. The wires running from the amp to my headunit are pluged in and I spliced the "Turn-on" wire into the Blue wire off my harness. Started it up and nothing at all.
I can not figure out anything that is going on, the little red emblem that is supposed to light up doesnt even light up, yet i know there is power running to the amp because I have checked it w/ a light. Now I did get the amp to light up but im not sure how so i do know the amp isnt broken.... Any suggestions would be very helpful, maybe a amp wiring diagram or something....
Old Nov 22, 2004 | 05:10 PM
fcm's Avatar
fcm
Old Fart
Default Re: Cannont get amp to work!!! pissing me off!! (Dawn Dreaming)
Th amp turn on lead on Alpine HU are blue/ white, the blue wire is a power ant. trigger wire, and will only have power on it when the radio is on, that said, if you want to check to see if the trigger is working, use a jumper from the B+ to the trigger on the amp to see if that turns on the amp, if not, and you have checked the power and ground, then you have a problem with the amp 94
Old Nov 23, 2004 | 07:00 AM
was
Default Re: Cannont get amp to work!!! pissing me off!! (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Th amp turn on lead on Alpine HU are blue/ white, the blue wire is a power ant. trigger wire, and will only have power on it when the radio is on, that said, if you want to check to see if the trigger is working, use a jumper from the B+ to the trigger on the amp to see if that turns on the amp, if not, and you have checked the power and ground, then you have a problem with the amp 94</TD></TR></TABLE>
check your remote wire!!
also, i'd use a voltmeter to check your power and ground... sometimes the inline fuses go bad, and look like they are still good... i've come accross a few cars that had that problem in my car audio days....
Old Nov 23, 2004 | 08:50 PM
SD350z's Avatar
Default Re: Cannont get amp to work!!! pissing me off!! (boosted y8)
yes..remote wire!
almost sure thats your prob.
Old Nov 24, 2004 | 07:11 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted y8 &raquo;</TD></TR><TR><TD CLASS="quote">
also, i'd use a voltmeter to check your power and ground... sometimes the inline fuses go bad, and look like they are still good... i've come accross a few cars that had that problem in my car audio days.... </TD></TR></TABLE> Ditto that If you have the glass barrel type fuse just relpace it to check, I have replaced a lot of them that looked good, evan tested ok, but as soon as you put a load on them they lost contenuity 94
8YourV8
Audio / Security / Video
13
Dec 11, 2010 09:50 AM
SIReg9
15
Mar 8, 2004 06:18 PM
brickonwheels
Jan 12, 2004 09:33 PM
intenseEK
23
Dec 17, 2003 06:54 PM
vtec-outlaw
Feb 4, 2002 12:45 PM
