Which spark plug wires?
Old Nov 22, 2004 | 04:08 PM
MtJavnk's Avatar
Default Which spark plug wires?
For testing purpose; can I use (is it safe) spark plug wires let's say from D16 on B16A2. I'm having some cold starting problems and I'm wondering if the wires are the problem.
If not, which wires can I use (beside the ones for B16A and B18C)?
Thanks!
Old Nov 22, 2004 | 04:11 PM
dohcMONSTER's Avatar
Default Re: Which spark plug wires? (MtJavnk)
go buy oem wires
Old Nov 22, 2004 | 04:19 PM
VIS250P's Avatar
Default Re: Which spark plug wires? (sohcMONSTER)
Buy NGK blue wire from summitracing.com.. Good Price...
Old Nov 22, 2004 | 04:23 PM
MtJavnk's Avatar
Yeah, but I'm looking for a used set to borrow, just to check if there's a problem with the ones I have.
Old Nov 22, 2004 | 04:25 PM
HATCHingMN's Avatar
Default Re: Which spark plug wires? (py)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py &raquo;</TD></TR><TR><TD CLASS="quote">Buy NGK blue wire from summitracing.com.. Good Price... </TD></TR></TABLE>
or from one from our h-t sponsor marketplace
I have NGK blues
Old Nov 22, 2004 | 04:30 PM
PRcivicHB's Avatar
what kind of problem are u having? maybe we can help?
Old Nov 22, 2004 | 04:39 PM
MtJavnk's Avatar
Default Re: Which spark plug wires? (PRcivicHB)
It's a wierd one
If the car sits for about 24 hours or more it would start and run only on 3 cyl. for a second or so. But ONLY when it sits for about 24 hours.
Before I cleaned the fuel injectors, the car wouldn't start at all. And after third or fourth try it would run on 3 cyl until the engine was revved up to 4.000 rpm.
I changed all 4 spark plugs. Battery is new, rotor/distribution cap should be OK. When the engine starts it runs OK. Although I have an idle problem - it's too low somethimes. And somethimes is ok.
So, now I'm checking ground cable on engine and the spark plug wire.
Old Nov 22, 2004 | 04:55 PM
PRcivicHB's Avatar
How do u know its running on 3 cylinders? did u get a CEL?
Old Nov 22, 2004 | 05:05 PM
MtJavnk's Avatar
Nope, no CEL ... but you can hear the engine. Strange sound, rocking as hell ... Also I did a check with pulling off the spark plug wires - cyl. 3 wasn't working.
Old Nov 22, 2004 | 05:29 PM
MtJavnk's Avatar
Anyhow ... which wires from other Honda engine can I use for the test?
Old Nov 22, 2004 | 06:02 PM
steve0unce's Avatar
if you say at idle you can hear like there is only 3cyl...do a cylinder power balance test to check out if one cylinder is out...there are 2 ways you can do it...but the way i do it is...have eng running...disable iac motor...then pull off one injector, and watch the idle...if it drops (should about 55 or less rpm)...plug it back up then do the same for others...if the idle doesnt drop and still runs the same thats the cyl thats messed up... dont know if that helped but worth a try
roachownsu
Dec 29, 2013 09:32 PM
raj_very
Apr 14, 2009 05:30 AM
jsrusse11
10
Nov 7, 2005 05:20 PM
osuperjohno
Jun 2, 2004 03:25 AM
1990hondaHF
25
Sep 28, 2002 06:18 PM
