D16A6 guys, how far are you able to advance your ignition timing before you run out?
Old Nov 22, 2004 | 03:43 PM
travis's Avatar
Default D16A6 guys, how far are you able to advance your ignition timing before you run out?
I'm curious to know how far you guys are able to advance your ignition timing before you run out of distributor adjustment. My current motor seems to have maxed out near 26 degrees. I just want to double check that this is in the normal range before I decide if I have to do something drastic to get it to go further. Thanks for any info.
Old Nov 23, 2004 | 02:55 PM
travis's Avatar
Default Re: D16A6 guys, how far are you able to advance your ignition timing before you run out? (travis)
Nobody knows?
BB6-213
Aug 24, 2005 07:59 AM
CRXLST
Oct 28, 2004 07:52 AM
BluLuder
Nov 6, 2001 02:41 PM
kahren
Oct 16, 2001 10:58 AM
