Car died while driving back last nite....
Old Nov 22, 2004 | 02:52 PM
krazie1's Avatar
BANNED
Default Car died while driving back last nite....
everything was fine just driving back from a show and then on the highway PuFF!! car died tried to down shift for power but nothing.
I pulled over and the car will fire up but then right away dies....
What do u guys think I should try checking without buying another motor please.
I have checked the 3 main rules of a normal start up (Spark, Fuel, and Timing) all seem to be in check
Could it be the ignitor???? As it is common in OBD1 and OBD2 to be the cause of this?
Please Help
Old Nov 22, 2004 | 02:59 PM
drdisco69's Avatar
Default Re: Car died while driving back last nite.... (krazie1)
You're saying you are getting spark? It sounds like an ignitor or coil, but if it's sparking, maybe not. Could have jumped a tooth on the timing belt.
Old Nov 22, 2004 | 03:04 PM
krazie1's Avatar
BANNED
Default Re: Car died while driving back last nite.... (drdisco69)
Yeah I check this theory about the tooth and it is on the mark
I have a external coil also I doubt but I guess I am in need of a dizzy to find out this theory also huh>???
Anyone else before I go in search of one......
Old Nov 22, 2004 | 05:31 PM
krazie1's Avatar
BANNED
no one????
Old Nov 22, 2004 | 05:55 PM
Combustion Contraption's Avatar
Pull off cap and rotor. Check the 3 wires that go to the ignitor for voltage with the key ON but the car not running. If there is voltage to all 3, and none of the wires were loose causing a bad connection, than the ignitor is bad and it needs to be replaced.
Old Nov 22, 2004 | 06:41 PM
krazie1's Avatar
BANNED
Default Re: (LsVtec92Hatch)
has a good ignitor all wires had power
I guess I am glad next though I have two new questions??
Would low oil level cause this also??
and well it fired up for like a two seconds and died, What can that mean?
Old Nov 22, 2004 | 07:20 PM
no, low oil would not cause that.
If it fired up for 2 seconds and dies, its probably fuel. Can you hear your fuel pump prime when you turn the key into the On position?
Old Nov 22, 2004 | 07:41 PM
krazie1's Avatar
BANNED
yes I can hear it
and would fuel delivery cuz it to actually fire up but not stay on I mean I can see I have 43 psi on my fuel pressure gauge
weird huh I wasn't even mashing on it just crusin' back from a showoff
Old Nov 22, 2004 | 07:43 PM
Yes fuel delivery could do that because if its pumping erraticly it would fire erratcicly. You also have some fuel left in the lines, rail, injectors when you first start the vehicle. Seeing as how you have a steady 43psi of fuel pressure, it doesnt sound like fuel is your problem. If you start the car and stand on the gas will it still die or will it rev?
Old Nov 22, 2004 | 07:46 PM
krazie1's Avatar
BANNED
Die!!!
once it even like back fired a tad
but the rest of the times just wouldn't do nothing like rev just Die as normal well at least in it's present state u know....
I am getting frustrated with my Crvtec
Old Nov 22, 2004 | 10:53 PM
baddog's Avatar
Default Re: (krazie1)
sounds like bad ecu.
Old Nov 22, 2004 | 11:08 PM
Sliced Beard's Avatar
Default Re: (baddog)
here are the problems that I have personally found to cause this
loose connections at fuel pump
bad ecu
and bad fuel filter
you will be amazed at how many people overlook the fuel filter
Old Nov 23, 2004 | 02:11 PM
krazie1's Avatar
BANNED
Default Re: (DirtySol)
ecu is a p28 w/s200 hondata system (new)
the fuel pump well I will check but I can hear it and see the fuel pressure on gauge
the fuel filter is a new AEM fuel filter I will check it out though
any one else has Ideas to look to
Old Nov 23, 2004 | 07:55 PM
krazie1's Avatar
BANNED
no one?????
I am missing driving my beast and nothing yet
I would like ot fix this myself and not tow it to the shop which is a bit about 2 hours away
Old Nov 24, 2004 | 10:51 AM
KillerBee's Avatar
the exact same thing just recently happened to me. all you guys can laugh, but my problem was a "dirty air filter"...cleaned it with kn&n charger kit and wala worked for me. on me for letting it get so dirty
Old Nov 24, 2004 | 03:12 PM
honda head's Avatar
maybe the alternator is bad
Old Nov 24, 2004 | 04:23 PM
krazie1's Avatar
BANNED
Default Re: (honda head)
okay Alternator seems to be on some of ur minds
so how can I check this out???
or get it tested??
Old Nov 24, 2004 | 04:55 PM
PrettyLude's Avatar
here's how u check the alternator, start your car, then take off your positive terminal, if the car dies, your alternator is gone
Old Nov 24, 2004 | 05:42 PM
Tad's Avatar
Tad
alternator is NOT going to cause the car to die,
UNLESS your battery is COMPLETELY DRAINED.
even if you completely removed the alternator, the car would run fine until it drained the battery completely.
i'm thinking distributor, have you tried swapping in a good-known dizzy?
Old Nov 24, 2004 | 05:57 PM
krazie1's Avatar
BANNED
Default Re: (Tad)
well I have a volt meter on the battery and it read 13.?? when the car was running and before the crank up or starting before it would read 12.78 or 12.67 sometimes
so this might rule out the alternator theory right??
I am thinking u guys might be right about the dizzy but the ignitor checks out voltage there. I got spark
Timing is dead on
I am thinking maybe fuel or something
any ideas guys need to get it running asap show this weekend
Old Nov 24, 2004 | 06:27 PM
Tad's Avatar
Tad
with the car running the batt should read 13-14v
any less and that means the alt isnt charging it right.
but yeh with it off it'll be in the 12's.. it isa 12volt battery afterall
and you say it starts then dies right? that means you're getting fuel.
do you have any CEL?
Old Nov 24, 2004 | 06:34 PM
krazie1's Avatar
BANNED
Default Re: (Tad)
no cel
and yeah everything is in check so far
but ne one??
Old Nov 24, 2004 | 06:41 PM
Tad's Avatar
Tad
compression test time man.
if I were you, i'd head out to the nearest autoparts store RIGHT NOW(thnx giving tomoro man, ***** gona be closed)
and get a compression tester, they're like 20bux, and the test is ez as fawk.
Old Nov 24, 2004 | 06:44 PM
krazie1's Avatar
BANNED
Default Re: (Tad)
I have one and did this already got 220 across the board
but what would compression have to do with this?
Old Nov 24, 2004 | 06:49 PM
Tad's Avatar
Tad
sign of a fawked up motor duh!
hehe, ok i dunno, fawk..
chek ur tps..
if everything was good before, ur compression is good,
your getting fuel, spark, timing... it's probly something fukin stupid!!
heheheh... maybe u sucked up some **** in ur intake pipe, ehhh i duno.
help me fix my electrical problem
https://honda-tech.com/zerothread?id=1066041
