got Spark, Fuel, Compression...still no running car
Old Nov 22, 2004 | 02:31 PM
EKB18BPR3's Avatar
Default got Spark, Fuel, Compression...still no running car
my car wants to fire up cuz it cranks and it sounds just like the first 2 seconds when u turn on a good running car but it just dont fire up. i got spark, fuel and compression 140-150-150-140 (CP pistons). me and 2 guys from HT worked on my car until 2am on saturday and i worked on it all day today. timing is perfect, firing order 1342 starting at bottom left, i just dont know. could any faulty sensors cause car not to start?
ps. how do i check if my fuel injectors are working? im getting fuel to the rail but i suspect that my injectors are not working. could all injectors have gone bad at once?
Modified by 98B00STED at 9:43 PM 11/23/2004
Old Nov 22, 2004 | 03:25 PM
sykotic's Avatar
what test did you use to make sure you had fuel?
Old Nov 23, 2004 | 12:38 AM
EKB18BPR3's Avatar
Default Re: (sykotic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotic &raquo;</TD></TR><TR><TD CLASS="quote">what test did you use to make sure you had fuel?</TD></TR></TABLE>
unscrew the bolt thats connected to the end of fuel rail that is opposite side of the fuel regulator, turn on the car and watched me make a mess.
Old Nov 23, 2004 | 12:43 PM
EKB18BPR3's Avatar
Default Re: got Spark, Fuel, Compression...still no running car (98B00STED)
bump
hYbRiD EeEkAy
16
Apr 19, 2008 12:37 PM
CRXWOLSKI
17
Jan 10, 2008 03:11 PM
lsvtecna
Mar 25, 2006 06:47 PM
Dan_the_MaN
Nov 15, 2005 03:04 PM
Sinner
Jun 8, 2003 03:03 PM
