Woundering if I can use a stock 92 civic radiator and fan on my 91 civic hatch D16a6?? Can anyone he
Will a 92 civic Radiator work on my 91 civic si hatch w/ a D16a6? Will this provide sufficient cooling for forced induction?
it will fit , but wont be good enough for your engine. dont use it, i wanted to before but my friend said it was all bad. ef's come with the bigger radiators for a reason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uglyasscrx »</TD></TR><TR><TD CLASS="quote">it will fit , but wont be good enough for your engine. dont use it, i wanted to before but my friend said it was all bad. ef's come with the bigger radiators for a reason</TD></TR></TABLE>
Um, how do I put this nicely. You sir are a fool. There, that is nice enough. An EG radiator is more then enough for the EFs and we want to put them in their to save space for turbo components and or cleaner engine bay. Search and you shall be enlighted.
Are you using a EG radiator in an EF turbo? Is there any difficulties in getting the radiatior and fan to mount and work properly? Can I use the EF stock fan? I appreciate all the help thus far!
1) I am personally not going to put my EG radiator in till spring since I am **** about the algorithm that covers my projects and since I have no turbo in there as of yet, I will hold of on it.
2) On fitment and such - https://honda-tech.com/zerothread?id=806969
Do a search for "Radiator" in this forum recent and archived and you will find a lot more info.
I have a 92-95 civic radiator in my crx. you could use the stock fan, but i bought an aftermarket for it was slimmer and had better airflow (more cfm). to get it to fit you need to fab some brackets or tilt the rad. just search and you'll find more answers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockhatch91 »</TD></TR><TR><TD CLASS="quote">Will a 92 civic Radiator work on my 91 civic si hatch w/ a D16a6? Will this provide sufficient cooling for forced induction?</TD></TR></TABLE>
Yes and yes. I've done it myself.
EGKevin209
Oct 27, 2010 01:23 AM
VELOCITY R
10
May 18, 2003 11:23 AM
