Je 10.5:1 pistons in a d16y8
Ok I have a 2000ex and I was thinking of putting in some je pistons. I have all the basic boltons I/H/E aem v1 cold air, greddy 4.2.1 header, rsr gt2 exhaust.
aem under drive pulleys and last a greddy e-manage for tunning.
with that said. what kind of power increase would I see with just adding the new pistons.
PS: my motor has about 31,000 miles on it
not much, i would go higher around 11-12 you cant get their with those pistons and a milled head or deck, welded up combustion chambers or you can keep it that 10.5 and boost or go nitrous, if your gonna go all motor and wanna go to a higher compression and a good cam that will be your best option otherwise keep the compression 10.5 and spray or FI it
what gas do you have access to?? if you only have 91 i would stay around 11:1 or less, if you can get 93 then i would stick around 12:1. this i my opinion, i would rather run more timing and have longevity.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch »</TD></TR><TR><TD CLASS="quote">what gas do you have access to?? if you only have 91 i would stay around 11:1 or less, if you can get 93 then i would stick around 12:1. this i my opinion, i would rather run more timing and have longevity.</TD></TR></TABLE>
well said
well said
Thanks for all the info guys its been a real help. I have decided that I will turbo my car for the meanwhile and just do a motor swap later.
I know but I have always wanted a type r swap. Its not really a power thing more or less haveing a car the way it was supposed to be from the factory.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si »</TD></TR><TR><TD CLASS="quote">i run 12.8:1 c/r on 91octane with no problems....</TD></TR></TABLE>
how?
how?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robtec »</TD></TR><TR><TD CLASS="quote">
how?</TD></TR></TABLE>
i call bullshit with robtec on this one, the only way it is possible is with significantly retarded timing and staying in low rpms. to the original poster, run 9:1 for boost
j0nb0y22
Oct 3, 2007 12:17 PM
jdm_sir2
Feb 17, 2007 01:54 PM
