All motor B series how to build a dream engine.
I go to college for automotive and i am in a class (Internal Combustion Engines) we just got a project that we need to find parts and build the most powerful B18 possible NA and use Dyno2000. These engines will not acually be built so money is not a factor at all. so if there are any flow charts of crazy heads or amazing cams and also stroker kits and crazy bore's these motors dont acually need to run but i need to have proof of these parts and of this stuff being able to work therothecly. so if aneybody wants to help me and send me some links of parts u think will work good. il keep everyone updated with the latest parts and HP numbers.
so far i have 295 hp at 10,000 rpm using crane stg 3 cams that are for a b18b because this program u cant use vtec and the ls cams have a higher lift. using 12:1 compression wiesco pistons 86mm and a 95mm crank i have 2.2 litres of displacement. now i need a good head
low13da9
Sep 9, 2014 03:51 PM
VashTheStampede
May 29, 2003 06:49 PM
