can anyone read JAPANESE here?? please translate
wow, this is going to be hard to translate for you.
my sister just tried to read what you scanned on...and she cant make out any chinese characters (they are too small)
Maybe because it's Japanese, numb nuts.
yea basically i need to know about which wires to hook it up to on the ignition, i can only do so much with pictures...
Also what the little adjustable **** is in the back with the X on it....
[Modified by trickie, 4:03 AM 12/29/2001]
japanese use chinese characters, numb nuts
Japanese?!?! Really?!!? I have you know that by just reading some of the kanjis that is in a paragraph you can pretty much figure out the meaning of the paragraph. Don't knock on it unless you know what people meant, other wise you just sound like a *****.
The only reason why I say this is because I basically passed my Japanese regents back in highschool by reading the kanjis...
The scanned text is a bit small to read...sorry.
that response anyway.
I don't know Japanese but I can still tell the difference between Kanji, hirigana, and katakana. In Japan you basically are at a big disadvantage if you can't read the Kanji (Chinese characters).
[edit]ok, i blew it up w/ photochop but it was still hard to read but
red = 12v constant
? = 12v when key is in ON position
blue = 12v when key is in ACC position
black = ground
brown = e-brake switch
the last one I have no clue what it says
[/edit]
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
red = 12v constant
black = ground
black = ground
Yoshi, Thanks alot that helps me there are a couple things i have questions about... on the top where it shows the harness then the P brake wire, then under that the ground wire, then under that there is another wire that doesnt seem to go anywhere what does it say by that?
Also towards the bottom there is a box with the #2 in the upper left corner, it shows a wire going to the positive side of a battery, what is that all about ? the wires that get power i thought were within the harness...
Thanks
Thanks
hey yoshi the second kanji is yellow
im pretty sure but the quality of the pic isnt great.
if its better ill translate it
the last one i cant even see it its just a blur.=\
dude u have got to be kidding me, the kanji all looks like a blur, ur gonna have to post a bigger can of it if u want a decent translation
