noob question from not so noob about a CEL CODE 41..
Quick question guys ..
I got CEL CODE 41: Primary Oxygen Sensor - Heater circuit malfunction
Do I need to swap my sensor, heater circuit, or is is the same thing ?? A diagram would be "peachy"
Thanks !!
Thanks !!
Disconnect the O2 sensor from the main engine harness. Using a multi-meter, measure the resistance between the two black wires (that are actually connected to the O2 sensor, not the engine harness side).
Is the reading between 15-40ohms? If no, replace the O2 sensor.
If you don't have a meter, then your guess is as good as anyone elses on here - so go with the shotgun approach to troubleshooting and just replace the thing.
Just what I needed to know !! However, I still have a doubt, is the "heater" part of the sensor or a different part ??
924drb20
Dec 14, 2010 10:36 AM
memorybox
May 27, 2007 08:19 PM
hondacivichatch
Mar 3, 2006 07:26 PM
nwarp
Jul 17, 2004 06:01 PM
