cp to high for a daily driven on 93 octane,tuned?
Old Nov 21, 2004 | 09:58 PM
90 integra's Avatar
Default cp to high for a daily driven on 93 octane,tuned?
i have a b18a1 block and head. im building my motor and whant to know if 12:1 or 12:5 cp is to high. its my daily driven car and im going to be using 93 octane every time. below is the set-up im going to be using.
b18a1 block bored .25 over stock sleaves
ls crank
ls rods
ctr pistons .25 over
ls head (how much do i need to mill to get to 12:xx cp?)
oem headgasket (maybe remove the middle layer to get to 12:xx cp)
crower 404 cams
im going to be using a hondata to tune it and will i need bigger injectors? which ones (its still obd-o)
if anyone needs more info about my set-up let me know and ill provide you with it.thanx
Old Nov 22, 2004 | 10:06 AM
90 integra's Avatar
bump
Old Nov 22, 2004 | 10:09 AM
PreStaged12s's Avatar
Default Re: (90 integra)
93 octane should be fine as long as you dont run to much advanced timing. Your lucky you have the luxury of pumping 93 at the pump, here in Ca I have to go to a racetrack and pump 96 @ $3.58 a gallon just to drive my car, 13.5:1 cr isnt very nice on 91 octane which is what we have at the pumps here.
Old Nov 22, 2004 | 11:02 AM
90 integra's Avatar
yeah i get 93 for about 2.05/gallon. and do you know which one would work the 12:1 or 12:5?thanx
Old Nov 22, 2004 | 11:42 AM
Used2beAb16's Avatar
You could get away with either depending on what kinda of tuning your will be doing. I would go with the 12.0:1 simply because then you can run some more timing. The power your gonna gain w/ that extra 5 points of compression is gonna be lost when u have to pull timing.
Another thought is what kind of cams, big *** cams with alot of overlap are going to allow you to run a higher static compression. The overlap will in a sense "bleed off" some of the compression resulting in a dynamic compression ratio that is lower than the static.
Old Nov 22, 2004 | 03:20 PM
Default Re: (Used2beAb16)
It really depends all on how you tune it, my friend has a 2.0l GSR with 13:1 cr running on 91 octane, his ECU is hondata tuned for 91 so he runs it that way it all depends on what you want.
Old Nov 22, 2004 | 03:51 PM
itralex's Avatar
Default Re: (PreStaged12s)
i'm doing alright as of now with 12.4 on 94 daily driven
g2turbo
Jun 24, 2014 12:17 PM
ghostofnyc
Oct 11, 2005 04:07 AM
spooncivic1
12
Nov 24, 2004 07:35 AM
QuarterMileMaster
Nov 18, 2004 12:15 PM
eh-D
Feb 6, 2002 05:25 PM
