Squeeky CRX
Old Nov 21, 2004 | 08:59 PM
Zeke28's Avatar
Default Squeeky CRX
Check it out, i threw some tokico blues with some sweet *** tenzo r purples (2.25) , and as soon as the car left the jack the rear passenger side would screech every time i hit the tinyest bump, like my tire was rubbing. but it aint the tire. my guess is the shock is fuct. I've searched through threads and found no help. any suggestions would be totally sweet. Thanks
Old Nov 22, 2004 | 06:37 AM
dr_latino999's Avatar
Default Re: Squeeky CRX (Zeke28)
Cheap springs if it has just started
Old Nov 22, 2004 | 03:24 PM
Zeke28's Avatar
Default Re: Squeeky CRX (dr_latino999)
so the spring blew out the shocks, or the springs are too ******?
Old Nov 22, 2004 | 03:35 PM
I don't think you would have blown the shock that quickly, probably the springs are the ones crying. You can test the shock though by this quick and pain-free method - get out of the car, push down on each corner pretty hard and let it come back up and stablize. If it stops quickly it's fine; if it's real bouncy it's blown.
Old Nov 23, 2004 | 04:17 PM
SwissChEz82's Avatar
I didn't even know Tenzo made springs.
Old Nov 23, 2004 | 04:43 PM
JnM4ev3r's Avatar
Default Re: Squeeky CRX (SwissChEz82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwissChEz82 &raquo;</TD></TR><TR><TD CLASS="quote">I didn't even know Tenzo made springs.</TD></TR></TABLE>
me too, do you have camber kits? It might be your camber kits, I had a similar problem with my gf's lude. After installing the springs and cambers, i set the car down and started to drive it around to see how it was. I was hearing squeeky noise from the front of the car and rear. I thought it was the springs untile I found out it was my camber kits... Did a few DIY to it and now it's squeek free!
Old Nov 23, 2004 | 09:27 PM
Zeke28's Avatar
Thanks for the help dudes! ill check evreything out. No i dont have chamber kits, i think its something rubbing. But swett, thanks
muddmonky
Suspension & Brakes
Jul 16, 2012 07:16 AM
ef yu
17
Oct 6, 2010 11:46 AM
chinkyx90
12
Feb 12, 2009 04:14 PM
pip9
Jan 15, 2004 04:06 PM
89hondarex
Dec 13, 2001 07:14 PM
