Type-R throttle body
Old Nov 21, 2004 | 06:47 PM
Zatzy's Avatar
Default Type-R throttle body
There are two sensors on the type-r tb....i know one is the TPS...what is the other?
Old Nov 21, 2004 | 06:51 PM
eda6's Avatar
Default Re: Type-R throttle body (Zatzy)
map sensor
Old Nov 21, 2004 | 06:53 PM
Zatzy's Avatar
Default Re: Type-R throttle body (eda6)
then what is on the backside of the intake manifold? i thought that was the map sensor
Old Nov 21, 2004 | 06:55 PM
eda6's Avatar
Type r intake manifold? If yes, then the only sensor back there is the iacv.
Old Nov 21, 2004 | 07:20 PM
Zatzy's Avatar
its not a type-r manifold. its a stock b16
Old Nov 21, 2004 | 07:23 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zatzy &raquo;</TD></TR><TR><TD CLASS="quote">its not a type-r manifold. its a stock b16</TD></TR></TABLE>
iacv It's in the same place on both manifolds.
Old Nov 21, 2004 | 07:24 PM
Zatzy's Avatar
thanx
Dent Free's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
iacv It's in the same place on both manifolds.</TD></TR></TABLE>
If the back is where it is then he's right
Old Nov 21, 2004 | 07:29 PM
JDM_Powered's Avatar
Speaking of throttle bodies, Which would you rather get, an Edlebrock 65 Mil for $300 or a Spoon 70 Mil for $500?
Old Nov 26, 2004 | 01:35 AM
Mike@K-Tuned's Avatar
Default Re: Type-R throttle body (JDM_Powered)
I wouldn't get either I'd get an rpm service T/B from AN-R.com they cost $310 shipped, awesome price and from what I hear they have no issues. Stock idle, bolt-on, no modifications needed. I'm ordering a 70mm to 68mm tapered as soon as they are in stock. These are by far the best T/B's I've ever seen.
check out AN-R.com
Old Nov 26, 2004 | 04:31 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Powered &raquo;</TD></TR><TR><TD CLASS="quote">Speaking of throttle bodies, Which would you rather get, an Edlebrock 65 Mil for $300 or a Spoon 70 Mil for $500?</TD></TR></TABLE>
I have seen both.
the JG Edelbrock is 64.2mm which is basically the same size you can get a GSR or second gen+ B16 Throttle body bored out to.
The Spoon throttle body is not 70mm at all. It is a 100% stock Integra type R throttle body that has been tapered at the opening to 70mm. It still has the 62mm ITR butterfly.
Old Nov 26, 2004 | 07:31 AM
Reelizmpro's Avatar
Default Re: Type-R throttle body (The new Spaceballs)
That's what I was wondering. I've seen people advertising these big *** 65-76mm TB's but when I ask them to measure the butterfly for me it turns out to be much smaller!
Old Nov 26, 2004 | 10:56 AM
krazie1's Avatar
BANNED
Default Re: Type-R throttle body (Reelizmpro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The new Spaceballs &raquo;</TD></TR><TR><TD CLASS="quote">
I have seen both.
The Spoon throttle body is not 70mm at all. It is a 100% stock Integra type R throttle body that has been tapered at the opening to 70mm. It still has the 62mm ITR butterfly.</TD></TR></TABLE>
This is so TRUE!!
That is why I got a Erick's rAcing TB which is actually made or machined by RPM
just in case none of u knew
Old Nov 26, 2004 | 09:22 PM
eda6's Avatar
Default Re: Type-R throttle body (krazie1)
I have the 72 to 70 mm rpm service tb. The gas pedal is really stiff. How do i loosen it up a bit?
Old Nov 27, 2004 | 04:12 AM
No Big Whoop
They use a very stiff spring. I worked on one of those a while ago and I replaced the spring with a modified stock Honda spring.
The guy who sent it to me didn't like the throttle body because it killed the cruise control. He said that the motor that opens the butterfly on the cruise control was not able to open it. Taking those throttle bodies appart is quite a job.
70mm is way overkill for an engine making under 250HP.
Old Dec 3, 2004 | 09:23 PM
Zatzy's Avatar
so for sure the two sensors on the throttle body are the tps and the map?
Old Dec 3, 2004 | 10:22 PM
doublethink's Avatar
70mm is way overkill for an engine making under 250HP. </TD></TR></TABLE>
whats the stock bore for a first gen b16a1???
Old Dec 3, 2004 | 10:57 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: Type-R throttle body (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">
Stock 1st gen is 58mm for B16A
2nd gen was a 60mm
type R TB are 62mm for the b series
Old Dec 7, 2004 | 05:21 PM
Zatzy's Avatar
Default Re: Type-R throttle body (Deetz)
anyone? is the two sensors on the type-r throttle body the map and tps?
Old Dec 7, 2004 | 05:37 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zatzy &raquo;</TD></TR><TR><TD CLASS="quote">anyone? is the two sensors on the type-r throttle body the map and tps?</TD></TR></TABLE>
YES.
Old Dec 7, 2004 | 05:50 PM
Zatzy's Avatar
so for sure the two sensors on the type-r throttle body is the map and tps?
Old Dec 7, 2004 | 07:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zatzy &raquo;</TD></TR><TR><TD CLASS="quote">so for sure the two sensors on the type-r throttle body is the map and tps?</TD></TR></TABLE>
OMFG.
Old Dec 7, 2004 | 08:13 PM
RCautoworks's Avatar
Are you joking, how many times are you gonna ask. http://www.acuraautomotiveparts.org , look for yourself.
Old Dec 7, 2004 | 09:11 PM
Zatzy's Avatar
Default Re: Type-R throttle body (90blackcrx)
sorry. computer fucked up and displayed that my post did not appear so i tried again yet it still did not show...so i said screw it...shut the comp down....now it says that both posts worked...my bad
sivikvtec
Dec 16, 2006 05:59 AM
racekar
Mar 31, 2005 05:11 AM
Toxic H
Mar 24, 2004 08:46 PM
integraver
Nov 3, 2003 04:30 AM
