someone please show me (map sensor?)
hey everyone i have a dohc zc in my hatch and today i was tryin to do(fix) my vaccume lines to fix idle ...ect. and when i got to the back of the fire wall i noticed a un-hooked plug hangin there and i believe it would goto a map sensor but i couldnt tell from the diagrams i found. so can some one please show me a pic. of there firewall(area) so i can see lines/plugs/map sensor by the way rthe wiring was a dx converted for the zc tia
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">The 3 pin connector is the map </TD></TR></TABLE> well i have a 3 "pin/prong" just hangin off the fire wall but i dont know what/where to plug it in??
thanks for the pics guys. now on the pic that dr.latino_999 posted it on the map sensor (lower plug) it's just hangin there can you guys tell me what is that doin to my car? also i conected all of my vaccume lines (except whatever the map is for) and i hear a vaccume leak and it sounds like it's comin from the intake manifold area.......does anyone know what that could be???
Are you referring to the plug hanging on the back side of the intake manifold near the firewall? Mines like that too, I forgot that plugs name, its an extra plug we don't need with our DOHCZCs. Lemme find the thread. brb - Darrell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://fourthgenhatch.com/zc.html »</TD></TR><TR><TD CLASS="quote">Vacuum Hoses
You will see that the Vacuum Hoses for the STD/DX and possibly Si aren't exactly in the same places. But here is how they should be hooked up.
Sensors on the firewall...
The 2 vacuum hoses from the MAP Sensor and Purge Solenoid Valve (PSV) are to be joined together with a "Y" Connector. You should not leave the hose from the PSV vented to the atmosphere because it's job is to open up to release the trapped hydrocarbons inside the charcole canister into the engine's intake manifold so they can be burned up. If you do not have this system hooked up properly the HCs will be released right into the atmosphere which is horrible for the environment. So do your small part and make sure you hook it up correctly.
Left Over Unused Plug: Orange, Black/Yellow
Help any?
</TD></TR></TABLE>Help any?
the plug that is undone on my car is the bottom plug on map sensor(nothin there to plug) what woud that do to my car? the reason i ask is because i hear a vaccume leak and i think it has to do with that hanging plug????
Jason, u had the sohc d16z6 a while ago, right??? Possibly they removed the map sensor from the firewall, becasue you were prolly using the one on the throttle body with the z6, just a thought.
Ryan
PS, will u be home for thanksgiving?? You can come buy and get one from me.
Ryan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote">the plug that is undone on my car is the bottom plug on map sensor(nothin there to plug) what woud that do to my car? the reason i ask is because i hear a vaccume leak and i think it has to do with that hanging plug????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">So are you sayin you dont have a map sensor?? I don get it, and yes the map sensor needs vac.
Ryan</TD></TR></TABLE> i guess so, i dont have a sensor(map) so can someone tell me what is the map sensor for? because ive all ways had idle issues after the swap and i need to know if no map sensor=bad idle/vac leak????
From: chillin in that city called queen creek, but homes the atl
yeh look at that picture very close becuase your map sensor is hooked up unless uuuuuuuuuuuuuuuuuuuu unplugged it
hatchinprogress
Nov 23, 2004 08:21 PM
