lookin for all b18c swap question for dizzy
Old Nov 21, 2004 | 04:43 PM
CrazyKoreanCrx's Avatar
Default lookin for all b18c swap question for dizzy
This is plain and simple question. Are anyone using a obd2 dizzy? If so what are you wiring color for the obd0 to obd2 for the dizzy. Thanks -Phil-
Old Nov 21, 2004 | 06:17 PM
520_Motorsports's Avatar
Default Re: lookin for all b18c swap question for dizzy (CrazyKoreanCrx)
using an obd 0 dizzy it is the easiest way to go also get obd0 injectors and such save yourself a lot of headache unless you are a wiring guru.
Old Nov 21, 2004 | 11:19 PM
BadWay's Avatar
obd2 dizzy no workie with obd0, one of the reluctors has different amount of teeth
Old Nov 22, 2004 | 12:41 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyKoreanCrx &raquo;</TD></TR><TR><TD CLASS="quote">This is plain and simple question. Are anyone using a obd2 dizzy? If so what are you wiring color for the obd0 to obd2 for the dizzy. Thanks -Phil-</TD></TR></TABLE>
Got your IM
I'm running OBD 1 everything. I cant help you with the wiring color question though, becuase my wiring was modified by somebody else.
Old Nov 23, 2004 | 06:02 PM
Kataku2K3's Avatar
Default Re: lookin for all b18c swap question for dizzy (BlueShadow)
You only need to worry about this if you're running an OBDI/II ECU. I've converted several of my friend's Rex's to OBDI but I always use OBDII distributors just because I like the single connector better! If you have converted to OBDI and need to still convert your dizzy connector over I can probably help ya. Just let me know. Good Luck
Old Nov 23, 2004 | 06:59 PM
Rywire's Avatar
Default Re: lookin for all b18c swap question for dizzy (Kataku2K3)
This is true, if you are obd1 now just refer to the obd0-1 jumper harness for directions. There is 2 different ways that I have seen. Locash does it 1 way, Blown90hatch does it the other way.
Ryan
Old Nov 23, 2004 | 08:23 PM
Kataku2K3's Avatar
Default Re: lookin for all b18c swap question for dizzy (droppedcrxsi)
You might have seen some of my stuff before but this is the way I do the conversion. These are what my nonOBD-OBDI jumpers and engine harnesses look like.
Rex harness torn apart with a few new extra connectors and VTEC stuff...
Completed nonOBD-OBDI jumper
All Done
Old Nov 24, 2004 | 02:19 PM
I already did all the conversion for obd0-obd1 with the jumper and four wire o2 sensor, vtec, knock sensor. The car starts and runs but after a day it won't start. Then it shoots a code 15. I'll give you the colors that I match up after it stops snowing with rain. -Thanks Phil-
Old Jan 27, 2005 | 06:08 PM
Bam! back from the dead. My car is running but now its throwing a code 15 again after figuring it but with a mechanic in Nov.. Like I was saying heres my wiring set-up.
Obd-0 Obd-2 In theory
1)Orange---------Yellow (this is wrong) Orange----Lite Blue
2)White-----------White ( ? )
3)White/Blue-----Red (This is right)
4)Orange/Blue---Green (This is right)
5)Blue/Yellow----Black (This is right)
6)Blue/Green----Lite Blue (This is wrong) Blue/Green----Yellow
7)White-----------Yellow/Green ( ? )
I'm still thinking that the white's are right but I dont know about 1 and 6 wiring. I would like a second opinion. -Thanks Phil-
-Also Thanks Kyle for helping with crx when it was throwing a code 15 while goin home.
Old Jan 27, 2005 | 08:43 PM
Last bump for tonite
Old Jan 28, 2005 | 01:47 PM
TallKyle's Avatar
haha no prob on helping u phil. bump...
Old Jan 28, 2005 | 05:51 PM
Default Re: lookin for all b18c swap question for dizzy (88slowcrx)
I hate this!!! still throws a code 15
obdo-----obd2
white---yellow/green
blue/green---blue/green
orange/blue---orange/blue
orange---orange
white---white
white/blue---white/blue
blue/yellow---blue/yellow
This is what i have and after i drive the car like a bad *** it dies and throws a code 15 again!!! . it just happen like 30mins ago
cticknor666
Nov 10, 2010 03:49 PM
toolbox21
Jul 25, 2008 06:41 PM
dohdoh420
Jan 22, 2006 01:59 PM
99hatchboy
Apr 23, 2005 02:56 PM
