Weighing options...input appreciated!
I am going to be buying another car real soon...most likely a 94-97 Accord EX, in sedan form with a 5spd. I want to swap in an H22 and leave it stock....is it worth it? Some say that they are not even that fast....what do you guys think?
The swap is a very good idea IMO but i guess it all depends on what you believe is good. the ex comes stock around 145 hp and with the swap you get around 190-200 i believe. If you think that a few thousand dollars worth a 50+ hp gain then go for it. Another option is the turbo on the f22. From what i understand a couple thousand dollars will get you the same HP and will be a little less costly.
spend $1500 in suspension mods, leave the engine stock and put the other $1000-$1500 in your pocket if you're gonna swap and leave everything else stock
/\rchCd5
Sep 12, 2014 01:37 PM
KanzenTaichou
Apr 4, 2008 10:27 AM
SmoKed917
Dec 15, 2003 06:45 AM
