vafc settings air fuel ?'s
Old Nov 21, 2004 | 03:07 PM
gsrx's Avatar
Default vafc settings air fuel ?'s
where should my approximate curve be on the vafc? what about vtec in/out? cant download specs from apexi...computer settings f'ed all up. dyno tested swap b18c1 w/ ctr cams car made 179 whp-131 tq ran fine then.....had bad connection on ecu. i tink vafc is wrong again. CAN N E 1 HELP A HOMIE OUT?
Old Nov 21, 2004 | 06:37 PM
ekgcool's Avatar
Default Re: vafc settings air fuel ?'s (gsrx)
The only way to set a VAFC is to either dyno or street tune it. Of course Dyno is best but also expensive. Street tuning is illegal, but free unless you get caught speeding. I wouldnt set it to someone else's motor. But in my case, I tuned my friends VAFC with VTEC at 4700, and the fuel curve going up 4% at 4000, then down to 2% at 5000, and ending at 5% at 6000 till redline. It woke the motor up alot. But that is with his B20 VTEC and 12.5:1 comp. Just play with it a little, and you can feel if you are making or losing power (to a certain point).
Old Nov 23, 2004 | 09:23 PM
s2kboy03's Avatar
Default Re: vafc settings air fuel ?'s (tekracer)
well both ways is good...yes dyno tuning the vafc does cost a lil more than street tuning...but my tuner was telling me street tuned is a lil better than dyno tuned cuz the temperature and air fuel is always different conditions so u won;t be getting that performance u get from dyno tuning..its pretty much just #'s...i street tuned my vafc with a wideband 02 and it made my power alot more open on a modded f20c...i dyno'd car after street tuned and made 17 whp from exhaust/testpipe and vafc...very hard to get gains on a s2000 with just bolt ons but i was very happy with results
Old Nov 24, 2004 | 01:35 PM
hybrid_vtec's Avatar
Default Re: vafc settings air fuel ?'s (s2kboy03)
using the butt dyno IMO would not very reliable, I think you should get an A/F Meter and test and tune at the track if you dont have the $ to dyno!
Im just saving $ to dyno, Im not going to ghetto-rig it!
Old Nov 24, 2004 | 01:51 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: vafc settings air fuel ?'s (hybrid_vtec)
I'm going to start street tuning my car with a wideband o2 gauge when I get it in... for now I'm just relying on a not so accurate Autometer, and I clean/pull the plugs after a run to make sure I'm not too lean, or too rich.
Old Nov 24, 2004 | 02:12 PM
Honda_Tengoku's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrx &raquo;</TD></TR><TR><TD CLASS="quote">where should my approximate curve be on the vafc? what about vtec in/out? cant download specs from apexi...computer settings f'ed all up. dyno tested swap b18c1 w/ ctr cams car made 179 whp-131 tq ran fine then.....had bad connection on ecu. i tink vafc is wrong again. CAN N E 1 HELP A HOMIE OUT? </TD></TR></TABLE>
my VTEC set at 4400 on my H22A. As far as VAFC fuel settings go to the dyno.
Team 4
37
Apr 23, 2009 11:39 PM
rohec04
Jul 2, 2005 01:45 PM
Behan
Jun 8, 2003 05:46 PM
bartek_b
May 11, 2003 10:03 AM
DB8
Jun 14, 2002 12:40 AM
