did a compression test and cylinder #1 has no compression the rest have 220
From: chillin in that city called queen creek, but homes the atl
like topic states cylinder #1 has zero compression the rest have 220. what do u think is the problem i looked thru the spark plug hole and the piston looks fine and it moves up and down if i rotate the motor. i'm guessing its either the rings are completely shot or its the valves seals. but i have never seen a motor with zero compression in a cylinder. o and it barely runs spitting out a gang of black smoke
I had no compression in a cylinder once and it was a burnt exhaust valve. Really it's the only logical explanation. You probably did not burn a hole in the piston, and the chances of your rings being 100% gone is slim to none, and intake valves don't usually burn unless the lash is too tight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhybrid85 »</TD></TR><TR><TD CLASS="quote">I had no compression in a cylinder once and it was a burnt exhaust valve. Really it's the only logical explanation. You probably did not burn a hole in the piston, and the chances of your rings being 100% gone is slim to none, and intake valves don't usually burn unless the lash is too tight.</TD></TR></TABLE>
i had 0 compression in my number four cylinder and my valves were fine. i melted a piston though. it could be detonation, but as they said, chances are its your valve.
cool cool keep the info coming
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothersickhatch »</TD></TR><TR><TD CLASS="quote">
i had 0 compression in my number four cylinder and my valves were fine. i melted a piston though. it could be detonation, but as they said, chances are its your valve.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dreams' profile »</TD></TR><TR><TD CLASS="quote">poormans r w/ 12.1 compression and lots of goodies</TD></TR></TABLE>
Yup, but he's n/a so there's a much smaller chance that he detonated enough to melt a piston. My vote's still on an exhaust valve.
its not my car its my homeboys car
dreamreaperx
Dec 20, 2006 02:01 PM
street dreams
Nov 21, 2004 05:12 PM
street dreams
Nov 21, 2004 04:48 PM
street dreams
Nov 21, 2004 02:44 PM
