Can you mix conventional and syn oil?
Old Nov 21, 2004 | 12:03 PM
VtecDA9's Avatar
Default Can you mix conventional and syn oil?
can you mix conventional mobile1 5/30 with sythetic 5/30? Or conventional and synthetic for that fact?
Old Nov 21, 2004 | 12:46 PM
IO_303's Avatar
Default Re: Can you mix conventional and syn oil? (VtecDA9)
mixing the 2 will cause your oil to break down faster. You will be fine going from conventional to synthetic, but not the other way, once you go synthetic it takes alot of work to go back to conventinal
Old Nov 21, 2004 | 12:59 PM
LudeyKrus's Avatar
Default Re: Can you mix conventional and syn oil? (IO_303)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IO_303 &raquo;</TD></TR><TR><TD CLASS="quote">mixing the 2 will cause your oil to break down faster. You will be fine going from conventional to synthetic, but not the other way, once you go synthetic it takes alot of work to go back to conventinal </TD></TR></TABLE>
If you call draining out the old oil and fillin the motor up w/ new synthetic oil too much work, then sure.
No, switching oils is not hard; just swap them when you change oil.
No, you cannot just add synthetic oil to conventional oil, or vice versa.
Old Nov 21, 2004 | 02:39 PM
IO_303's Avatar
Default Re: Can you mix conventional and syn oil? (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">
thats fine if you are going to synthetic, but going the other way its not as easy
Old Nov 21, 2004 | 02:51 PM
LudeyKrus's Avatar
thats fine if you are going to synthetic, but going the other way its not as easy</TD></TR></TABLE>
Yes it is.
Ask me how I know.
Old Nov 21, 2004 | 03:10 PM
drdisco69's Avatar
Hey LudeyKrus, how do you know?
Old Nov 21, 2004 | 03:12 PM
LudeyKrus's Avatar
Default Re: Can you mix conventional and syn oil? (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Hey LudeyKrus, how do you know? </TD></TR></TABLE>
Because i've done it! Mwuahahahahahahahahahahah! [/sinister laugh]
C_H_A_D
12
Jul 10, 2008 04:49 PM
ahron
Sep 9, 2007 06:59 PM
Vouthanack
Jul 30, 2004 11:18 AM
Steve26
Jul 29, 2004 05:09 PM
itr1244
Jun 18, 2004 12:42 PM
