1988 Accord Carb A20A
Old Nov 21, 2004 | 11:07 AM
Charlescox's Avatar
Default 1988 Accord Carb A20A
Start my car and it Idles at 2500 for about 2 mins. then the idle increases and when i push the gas the idle drops down to 100 rpm and the car dies. Just wondering if you could help me out and tell me what I can do to fix it. This has happened before but the car just fixed itself i guess. This started happening this time when I was parking put parking break on forgot to TAKE CAR OUT OF GEAR, released the clutch and killed it. That is when it started doing this again.
Old Nov 21, 2004 | 07:17 PM
92 CIVIC HATCH VX's Avatar
Default Re: 1988 Accord Carb A20A (Charlescox)
bump
Old Nov 22, 2004 | 04:18 AM
Charlescox's Avatar
confused? Driving my car to work today lost all power but it was not the alternator kind of like i lost fuel pressur. Gas pedal was to the floor and the highest the tach would go is 4000. Also tried to shut it off and it would not shut off I really don't understand please HELP
Old Nov 22, 2004 | 07:03 AM
toughlou's Avatar
I just got rid of my carb 1986 and had a similar problem
The car would not shut off after I turned it off, kept rumbling
Also had the same problem with the hard idle
Guess what you need a new carburator.
I decided to junk the car instead a new honda carb is $700.
Old Nov 22, 2004 | 07:38 AM
Charlescox's Avatar
BUMP
Old Nov 22, 2004 | 12:10 PM
Charlescox's Avatar
BUMP
SOMEONE PLEASE GIVE ME SOME MORE ADVICE
Old Nov 23, 2004 | 04:42 AM
dr_evil2005's Avatar
i had the same problem also. i checked the fuses under the hood and replaced the blown ones and recharged mt battery and it runs like it should now.
hope that helps
evil.
Old Nov 28, 2004 | 06:39 AM
Charlescox's Avatar
Default Re: (dr_evil2005)
took car to a mechanic he said i had a whole in my carb diaphram and it was causing my choke to stay on full. Replacing the carb is costing $400-500..
thanks for all of your help guys
Rage97
Aug 19, 2013 12:11 PM
StockDC2
Mar 31, 2013 07:30 AM
EddiEEchung
Sep 30, 2007 10:59 AM
blowtizzle
Jan 2, 2005 01:41 PM
