Turbosmart wastegates, starting @ $275 SHIPPED
We are having a sale on all Turbosmart wastegates. Please Click on "BUY NOW" next to the price below and you will be taken to the shopping cart to make your purchase. Thank you.
Ultra gate 35mm features $275 SHIPPED BUY NOW
The most compact 35mm wastegate on the market, featuring the common two bolt flange design used by many turbo kit manufacturers. The Ultra-Gate’s design incorporates a unique temperature isolation zone to reduce heat transfer, a true 35mm inlet port for maximum flow, an investment cast Stainless Steel body and one-piece valve for strength and reliability. Turbosmart have successfully used one Ultra-Gate on engines producing up to 600HP.
*Ultra compact 112mm overall height (4 ½ inch) and 100mm across (4 inch)
*17-7 PH spring and Silicone Nomex diaphragm - durability under extreme temperatures and stress
*Optimum actuator to valve ratio for precise boost control
*Superior body design and huge valve lift ensure unrivalled flow
*Supplied with weld on steel manifold flanges and gaskets
*Supplied with 7, 10, 14 and 17psi springs.
Pro Gate 45mm features $465 SHIPPED BUY NOW
The Pro-Gates design includes an investment cast Stainless Steel body, a one-piece valve for strength, reliability and the unique temperature isolation zone to reduce heat transfer. The Pro-Gate is supplied complete with a cast Stainless Steel Vee-band adapter kit for quick and easy installation. Turbosmart has used their Pro-Gate on engines producing up to 1000HP.
*Extensively developed body design and huge valve lift ensure unrivalled flow
*Supplied with Vee-bands and weld flanges
* Supplied with 7psi(already installed), 10, 14, 17 and 21psi springs.
Modified by Nonstop at 9:52 AM 12/24/2004
Modified by Nonstop at 4:44 PM 1/8/2005
Boostfed
Nov 29, 2012 07:56 PM
Co0p3r
Oct 23, 2009 06:10 PM
