fs/93 cx civic/build motor philadelphia
93 cx 135,00 on body
rota grids rims barelly used
no name coilovers with skunk2 drag springs
ls/vtec engine with less than 1,000 miles on it,the engine built up consist of the following:
ls block done by bensons 83mm bore
acl bearing all around
cp 9:1 pistons 83mm
pauter rods
brand new oil pump,water pump,timing belt,tensioner,all gaskets from honda
cosmetic head gasket
arp head studs
fully ported and polished b16 head with supertech springs,retainers and valves
hondata intake manifold gasket
skunk2 intake manifold with bore trotle body to 68mm
golden eagle fuel rail with aeromotive regulator,all braided lines for fuel from stan
gsr tranny with with act extreme and six puck clutch and type r flywheel
jdm dc header with modified colector 2.5 inch wraped around with termo tec
walbro 255 hp fuel pump
msd 6al with 2 step
proform shift light and autometer oil press gauge
msd cap and ignitor
everything in this motor is brand new,i got receipts for the motor also for parts
is a clean title really well kept and babied.it took me a year to buil this car and due to debt issues i will let it go for 8,000 obo price is negotiable trades if you got money back for me,if you need the vin number let me know also
located in north philadelphia,email me for pictures
cp 9:1 pistons 83mm
pauter rods
arp head studs
msd 6al with 2 step
msd cap and ignitor
