GSR vs ITR front CV axel.. the same or diff??
Old Nov 21, 2004 | 09:31 AM
mikeweb's Avatar
Default GSR vs ITR front CV axel.. the same or diff??
I need to replace the front outer passanger side cv axel on my GSR, but my local store only have one for an ITR. Would an ITR axel work on a 96 GSR?
Old Nov 21, 2004 | 09:38 AM
DontBlink's Avatar
Default Re: GSR vs ITR front CV axel.. the same or diff?? (mikeweb)
yea. the only differance between any of the B series axles is some came without abs rings on them.
Old Nov 21, 2004 | 10:01 AM
Willard's Avatar
Default Re: GSR vs ITR front CV axel.. the same or diff?? (DontBlink)
der... don't most all DC2's have abs?
the difference that I notice is the lack of the thick rubber ring in the middle of the cv shaft.
Old Nov 21, 2004 | 10:08 AM
DontBlink's Avatar
Default Re: GSR vs ITR front CV axel.. the same or diff?? (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">der... don't most all DC2's have abs?
sorry, just tring to help. i'll stop now
Old Nov 21, 2004 | 10:09 AM
Willard's Avatar
I could be wrong.
Old Nov 21, 2004 | 10:22 AM
AssPenny's Avatar
the difference that I notice is the lack of the thick rubber ring in the middle of the cv shaft.</TD></TR></TABLE>
All DC2's are ABS to my knowledge, so in this case, the ITR and GSR axle should be the same when it comes to a rebuilt DS.
However, dontblink was correct when he mentioned not all b-series driveshafts are setup for ABS. All B series cars are not DC2s after all.
Old Nov 21, 2004 | 10:33 AM
JDMluvR's Avatar
Default Re: GSR vs ITR front CV axel.. the same or diff?? (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">
All DC2's are ABS to my knowledge</TD></TR></TABLE>
I thought 94 RS didn't come with ABS. I could be wrong too. Anyway back to the subject.
Old Nov 21, 2004 | 10:34 AM
AssPenny's Avatar
Default Re: GSR vs ITR front CV axel.. the same or diff?? (JDMluvR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMluvR &raquo;</TD></TR><TR><TD CLASS="quote">
I thought 94 RS didn't come with ABS. I could be wrong too. Anyway back to the subject.</TD></TR></TABLE>
RS != DC2.
DC2 = VTEC 3Door
Old Nov 21, 2004 | 10:37 AM
Dan GSR's Avatar
Nerd
i guess that makes me a nerd to, since i know what that is
Old Nov 21, 2004 | 10:44 AM
JDMluvR's Avatar
OOPS! My bad
Old Nov 21, 2004 | 11:16 AM
mikeweb's Avatar
Wicked.. thanks for the reply..
Question though.. whats the thick rubber ring in the middle of the cv shaft for?
Old Nov 21, 2004 | 12:04 PM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeweb &raquo;</TD></TR><TR><TD CLASS="quote">whats the thick rubber ring in the middle of the cv shaft for?</TD></TR></TABLE>
vibration dampening?
most aftermarket shafts don't have the ring.
Old Nov 21, 2004 | 01:04 PM
jungletronic's Avatar
An itr axle will not fit on a GSR unless you have itr hubs.
Old Nov 21, 2004 | 01:21 PM
ZygSpeed's Avatar
Default Re: GSR vs ITR front CV axel.. the same or diff?? (jungletronic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jungletronic &raquo;</TD></TR><TR><TD CLASS="quote">An itr axle will not fit on a GSR unless you have itr hubs.</TD></TR></TABLE>
The 32mm ITR hubs, .... or the 36mm (JDM) ITR hubs?
USDM GSRs and ITRs both come with 32mm hubs. Ed
Old Nov 21, 2004 | 01:33 PM
PM-Performance's Avatar
Not really didnt they just start ,making them standard in 97?
Old Nov 21, 2004 | 01:34 PM
Default Re: GSR vs ITR front CV axel.. the same or diff?? (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">
USDM GSRs and ITRs both come with 32mm hubs. Ed</TD></TR></TABLE>
Old Nov 24, 2004 | 08:35 AM
touche
Old Nov 24, 2004 | 08:46 AM
chad's Avatar
Moderator
WRONG!!!!!!!!!!!!!!!!!
I have 2000 itr axels on my 95 gsr hubs!!!!!!!!!!!!!!!!!!!!!!!!!!!!
unless you are talking about jdm itr axels 98spec which are 36 mm as ED stated!!!
Old Nov 24, 2004 | 08:47 AM
hypa's Avatar
That's good to know.....
thanks!
mlrmotorsports
Jul 26, 2007 02:41 PM
Ireland-rex
Jul 24, 2005 10:46 AM
The Flying Dutchmen
Jun 9, 2005 07:56 PM
deviant1
13
Mar 7, 2005 07:33 AM
hondastreet
Jan 14, 2004 08:09 AM
