ITR Cluster swap into a EG6 ????
Old Nov 21, 2004 | 09:13 AM
Wuman's Avatar
Default ITR Cluster swap into a EG6 ????
Anybody knows if it works or fit?
Thanks
Old Nov 21, 2004 | 09:19 AM
GSlowR's Avatar
Default Re: ITR Cluster swap into a EG6 ???? (Wuman)
i've seen people that have done it.. i heard that the main thing is you gotta shave down some of each side to get it to fit.. other than that i think it just clips in...
Old Nov 21, 2004 | 09:30 AM
Wuman's Avatar
Default Re: ITR Cluster swap into a EG6 ???? (GSlowR)
But you can plug the oem pugs from a EG into a ITR cluster?
Old Nov 21, 2004 | 09:45 AM
GSlowR's Avatar
actually i am wrong you do have to cut some stuff up.. not sure where a diagram is tho
Old Nov 21, 2004 | 09:50 AM
GSlowR's Avatar
http://www.geocities.com/_nitr....html might help you out..
Old Nov 21, 2004 | 09:59 AM
GSlowR's Avatar
found another link.. by searching.. http://patriot.net/~merritt/gauge.html
Old Nov 21, 2004 | 10:00 AM
Wuman's Avatar
Thanks But i have a 94 EG6
Old Nov 21, 2004 | 10:22 AM
GSlowR's Avatar
second link has the pinouts for 92-95 civics
Old Nov 21, 2004 | 08:47 PM
PrettyLude's Avatar
most of the diagrams work, i used them myself, but the main problem would be getting everything to fit right
Old Nov 21, 2004 | 10:23 PM
Supahr_Ed's Avatar
nice info,
will the black plastic bezel need to be cut in a EG for the DC cluster to fit?
Old Nov 22, 2004 | 09:38 AM
cxSHOE's Avatar
it does fit and works fine look in my sig. to get an idea of what your suppose to cut to the bezel.
noloveforstock21
Aug 28, 2008 06:38 PM
jb07_
Mar 5, 2008 05:11 PM
gameboi
Nov 18, 2005 06:34 PM
eg6turb0
Aug 8, 2004 10:35 AM
