EG cluster
Old Nov 21, 2004 | 05:47 AM
daidilus's Avatar
Default EG cluster
I have an EG cluster that i will be fabbing into my car...i need to find the wiring diagrahm for it...can anyone help me out?
Old Nov 21, 2004 | 05:55 AM
mrspeaker's Avatar
Default Re: EG cluster (daidilus)
Even if you wire it up ,you have to cut up alot of **** to make it fit
and plus its ugly ...The 94-01 teg looks alot better IMO..or jdm teg clusters
You'll need electric vss at the least ..
I dont even know if any one has ever done this cluster swap before before..
Old Nov 21, 2004 | 11:04 AM
daidilus's Avatar
Default Re: EG cluster (Mrspeaker)
, i already have a DC2 cluster wired in, i got the wiring diagram and added the EG cluster plugs to my existing ones.....only things that worked was the turn signals though..i may have forgotten the power wire..i will try again when i get home! the first swapped car i drove was a B18C EJ, i love the EG cluster...it will be done!
Old Nov 21, 2004 | 11:49 AM
POE's Avatar
POE
i personally like the DC2 cluster in your car man i think that looks hot, but i have an EG with an Eg cluster in it so.. maybe im just bored
Old Nov 21, 2004 | 01:08 PM
daidilus's Avatar
well my fav honda in the EG...but i am stuck with a EF the only thing that makes up for having a suck *** car, is the SiR swap with ITTR cams...and still i would trade the entire thing for a stock..EG
Old Nov 21, 2004 | 01:20 PM
XJamesX's Avatar
Default Re: (daidilus)
I tried it in a crx. the cluster does not fit without either cutting the dash or the cluster. I did not bother finishing it because the person I was doing it for didn't wannt to cut anything. The wiring shouldn't be that hard. Here i smy 99-00 civic cluster swap write up. It will help you with the crx wiring at least. Just get a manual for the EG and figure out the wiring. Or you could just follow the circuts on the back.
https://honda-tech.com/zerothread?id=709958
-James-
Old Nov 21, 2004 | 01:53 PM
daidilus's Avatar
LOL..i used that to install my DC2 cluster...i like the EG better though..the wires will be fixed, and soldered tonight!!
Old Nov 22, 2004 | 09:21 PM
NGUSPEED's Avatar
By DC2 Cluster are you guys talking about the RSX Cluster? I wanted to know if those would work too.
doubleoazn03
Nov 9, 2008 07:41 AM
jadugartir
Oct 9, 2006 07:42 PM
BubLBack
12
Sep 7, 2006 09:23 PM
