LS Vtec
Sorry if the question that am about to ask dont bother other foos that think they know everything and think theyre the ****.
Am sort of a newbie and am just tryin to lern new ****.
Why does the LS Vtec come out to be soo powerful when ur only putting a B16 head to a B18b block???? wouldnt it be better if u put a B18c or b18c5 head to it???
Teach me here am really confused....
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Db2_iNtEgRa »</TD></TR><TR><TD CLASS="quote">oh allrite so like ur LS Vtec is stronger than another one that has a B16 Head?</TD></TR></TABLE>
Yes, with the bigger ITR cams and better flow than the B16 head he will make more power than with a B16 head. Out of all the heads the B16 will make the least power because it has the smallest cams. The GSR is second to the ITR, it has a smaller combustion chamber for a bit more compression as well as more agressive cams than the B16.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboEGsedan »</TD></TR><TR><TD CLASS="quote">
Yes, with the bigger ITR cams and better flow than the B16 head he will make more power than with a B16 head. Out of all the heads the B16 will make the least power because it has the smallest cams. The GSR is second to the ITR, it has a smaller combustion chamber for a bit more compression as well as more agressive cams than the B16.</TD></TR></TABLE>
what he said, + it also makes more power because i built my bottom end and did , some more work on the head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm92daintegra »</TD></TR><TR><TD CLASS="quote">
what he said, + it also makes more power because i built my bottom end and did , some more work on the head </TD></TR></TABLE>
Exactly. Most people that do ls/vtec (well at least those who do it RIGHT
) also do many upgrades to their engine (meaning head AND block) as well... For instance, people will swap out pistons/rods for ones more serving to their purpose, or machine the head for better flow, etc... all at the same time.
orgasmicsensations
Apr 3, 2003 07:34 PM
