b18a into 88-91 std questions
Old Nov 20, 2004 | 11:59 PM
hinds90's Avatar
Default b18a into 90 std questions
i have a 88-91 civic hatch 4spd and i have a b18a motor with trans, wiring harness, all 4 stock mounts, axles, ecu, resistor box and shift linkage. I was wondering what else do i need for the swap and can I use the 4 stock mounts. I have seen a lot of post about this topic but some say the std is not the same as other 88-91. I have also been told that you have to change out hubs and things like that. Thanks for any replies.
Old Nov 21, 2004 | 01:53 AM
red civic standard's Avatar
Default Re: b18a into 90 std questions (hinds90)
you will have a few thinigs to take care of:
1. mounts. you have to get aftermarket mounts and shift linkage. try hasport.
2. wiring. your car is duel poiint fuel injected (DPFI) and must be converted to multi point fuel injection (MPFI)
3. hubs. you must get some 88-91 civic/crx dx or si hubs to take the new axles.
4. axles. use 90-93 Integra axles and intermediate shaft
90civSi
Oct 12, 2006 10:30 AM
b16a1eg6
Feb 28, 2006 02:29 AM
gsrhb7
Jun 1, 2004 09:24 AM
IDriveHonda
79
Dec 4, 2003 02:32 PM
