stumbles/chokes 90 EX
Old Nov 20, 2004 | 09:24 PM
missionary's Avatar
Default stumbles/chokes 90 EX
Hey Gang,
90 Accord ex 4dr 5sp 95k on 2nd engine
Start it cold runs fine at idle and driving. As soon as it's warm it begins to hesitate/stumble hard from a stop into acceleration. I can give it a bunch of pedal and ease the clutch out to get it moving from a stand still and minimize this problem. This problem developed from a light version of what I described, to this over a 3 month period. Problem used to only be around town, now on the freeway I give it gas and it stumbles constantly unitl I get it up to a constant speed then it stops.
At warm idle has a bit of a miss or it stumbles down a bit. Mostly stays constant. Seems it appears only when I'm requesting some low end torque.
I have:
-replaced the ignitor/coil/cap/rotor
-replaced the fuel filter
-replaced pcv valve
-followed my haynes manual on checking the EGR valve all seems to be in check
-disconnected the vaccuum line from EGR to see if idle improves -nothing
-codes for my speed sensor only. (cuz it's out)
Anything common I'm missing?
Thanks alot.
-Jason
H0ndas g0 Vr00m
Honda Civic (2001 - 2005)
17
Mar 11, 2008 07:53 PM
easymac
Feb 25, 2008 04:38 PM
fire_fighter97
Aug 6, 2007 05:58 PM
willyboyK20
Sep 10, 2003 12:35 PM
willyboyK20
Jul 25, 2003 11:26 PM
