Which swaybar?? Help me make an informed source!1
Old Dec 28, 2001 | 08:52 AM
ceas's Avatar
Default Which swaybar?? Help me make an informed source!1
The car - 00cx
motor - b18
current suspension - apex'i n1 - 99 spec.
tires - will be falken azenis
desired driving - small puts around as daily driver - weekend track car (vir, summit point, etc..)
rear bar - comptech 22mm
My choices for front bar are the Suspension Techniques 15/16ths, Progress 25mm, or perhaps find a SI front setup including the arms and shock forks.. Does anyone have experience with any of these setups, or could perhaps give me some advice on running one of them?? As most of my local tracks are of the higher speed varity - I would hate to have a car that gets a little too squirly.. Thanks
ceas..
Old Dec 28, 2001 | 08:57 AM
Spade's Avatar
Default Re: Which swaybar?? Help me make an informed source!1 (ceas)
The Si front is 26mm.......the rear is 13mm HMMMM something about balance to look at there.
Old Dec 28, 2001 | 09:03 AM
ceas's Avatar
Default Re: Which swaybar?? Help me make an informed source!1 (Spade)
This i know - but a Si with the stock front bar and the comptech rear 22mm drives perfect for me - I had the chance to drive one fairly hard and it is almost perfectly balanced. The stock Si setup pushes.. My wheelbase is the same as the Si, so the 26/22mm would probably feel right around the same in my hatch. My real concerns are the way that the other two swaybars are mounted, as that can also change the "virtual thickness" of the bar, as well as quality of product..
ceas..
Old Dec 28, 2001 | 09:07 AM
Spade's Avatar
I would get the stock SI bar for the simple fact that it was made to go into a civic. sure you have to get the other parts but, do you really want to risk (espically on the track at high speeds) loosing/ripping a bracket?
Old Dec 28, 2001 | 10:45 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
leave the stock front bar, you don't need anything bigger than what you have. some guys don't even run a front bar at all......personally, i run a stock 21mm up front with a mugen 26mm out back.
Old Dec 28, 2001 | 11:31 AM
Mike P.'s Avatar
25 Year Member
Default Re: Which swaybar?? Help me make an informed source!1 (rodney)
a '00 CX ain't got no front bar (or rear bar, for that matter). With a Comptech rear, no front bar will be a handfull on the track. There is a reason the higher performance models come with the bars from the factory.
Old Dec 28, 2001 | 11:43 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Which swaybar?? Help me make an informed source!1 (Mike P.)
There's also reasons why the factory ECUs are slightly de-tuned too - the average joe customer has to drive the car every day.
The average joe might wreck the **** out of his car while "rodding" around with a thicker rear bar and no/smaller front bar.
Old Dec 28, 2001 | 12:10 PM
Mike P.'s Avatar
25 Year Member
Default Re: Which swaybar?? Help me make an informed source!1 (B18C5-EH2)
This average joe has driven his coupe with the Comptech rear and the front disconnected and it's no good for the track.
Old Dec 28, 2001 | 12:25 PM
owen_the_soyboy's Avatar
leave the stock front bar, you don't need anything bigger than what you have. some guys don't even run a front bar at all.......
ditto
Old Dec 28, 2001 | 01:20 PM
B18C5-EH2's Avatar
Former Moderator
Loved
I understand, but there's also a reason why companies make these bigger rear bars. somebody's buying them and using them, right?
I'm no swaybar expert, but I do know that if somebody practices enough and gets a lot of seat time with a particular set-up that they might really enjoy it. Such as a big rear bar and no front bar.
Old Dec 28, 2001 | 01:23 PM
Mike P.'s Avatar
25 Year Member
Gotcha...all I'm saying is that in my experience, the car becomes sloppy with no front bar and a Comptech 22mm out back. I've tried it.
Old Dec 28, 2001 | 01:54 PM
Halo's Avatar
I'm running the Si bar upfront on my 97 hatch, and I love it! The comptech rear bar looks sweet, but not $369 sweet
Old Dec 28, 2001 | 02:51 PM
ceas's Avatar
Default Re: Which swaybar?? Help me make an informed source!1 (Halo)
the cx has NO front - or rear swaybars as standard..
ceas..
Old Dec 28, 2001 | 03:07 PM
Jackson's Avatar
i had just the 22mm rear bar, and by adding the si front 26mm bar, it helped out so much. for the average joe, they give the si the 13mm rear bar so he doesnt go swinging his back end around trying to make that left turn when the light just turned yellow. 26mm front and 22mm rear is a good combo.
Old Dec 28, 2001 | 04:14 PM
TurboSedan's Avatar
New User
Default Re: Which swaybar?? Help me make an informed source!1 (Jackson)
I agree, for MOST people a front bar is a must when having a thick *** rear bar. I plan to run my stock 22mm front with the 19mm ST bar next year for auto-x. I think it will balance nice.
Old Dec 28, 2001 | 04:24 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Which swaybar?? Help me make an informed source!1 (97CivicFerio)
I like the design of the Comptech piece - it incorporates a chassy brace along with the mounts for the swaybar. This could help prevent any subframe stretching on the EG-style Civics.
I see a lot of VW guys just take their front bars off and 3-wheel around the auto-x courses and SPANK a lot of *** like that. Is it totally different for us with Hondas?
Old Dec 28, 2001 | 05:36 PM
B18C-EJ1
Guest
Posts: n/a
My vote - SI bar. Get all the LCA's and stuff with it too!
Old Dec 28, 2001 | 05:37 PM
deepnite's Avatar
i run a progress bar in the rear..none in front of the 98 dx..runs good..ive heard that neuspeed s is pretty good too..
Old Dec 28, 2001 | 07:17 PM
Mike P.'s Avatar
25 Year Member
I tell ya, my Si does that WITH the front bar attached. (and the 22mm rear) And I don't mean like a centimeter....more like 8 inches or so. With the front bar disconnected, it almost gets scary. Shock settings probably have a lot to do with that, but that's all autocross. (Where the speeds are relatively low, and the danger level is almost non-existant.) On a race track at approaching triple-digit speeds, that bar (front and rear) is wonderful.
Old Dec 29, 2001 | 07:46 AM
Yesman's Avatar
New User
i would go with the stock Si swaybar.
JDMillio
Suspension & Brakes
Oct 26, 2009 11:16 AM
JJ-Built
Suspension & Brakes
Nov 3, 2005 01:08 PM
x00gsr
May 20, 2003 09:52 PM
EBPSI
Oct 7, 2002 11:24 AM
ceas
Dec 29, 2001 10:17 AM
