Aluminum or steel wheel spacers
Old Nov 20, 2004 | 07:49 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Aluminum or steel wheel spacers
I have a set of 15x6.5 Rota slips and up to now I have never used any spacers to center the wheels on the hub (I doubt this can be an issue since the lugs are being torqued to 80ft/lb). However, I am still a little uncomfotrable with the weight of the car being supported by the wheel studs . Where can I get a set of almuninum or steel spacers and what size should I be looking for? Thanks!
Old Nov 20, 2004 | 09:31 PM
Padawan's Avatar
Darth ModerVader
Default Re: Aluminum or steel wheel spacers (FrostyDC4)
If the only reason you want the hub-centric rings is because you're looking for additional "support", don't bother with them. The rings are not designed or intended to provide any sort of support, they're simply made to help center the wheel during installation (many are even made of plastic). The lugs/lug nuts and the frictional force they create against the rotor are what supports the vehicle. Just make sure you're using proper tapered-seat lug nuts with the wheels.
Old Nov 21, 2004 | 03:39 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Aluminum or steel wheel spacers (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">If the only reason you want the hub-centric rings is because you're looking for additional "support", don't bother with them. The rings are not designed or intended to provide any sort of support, they're simply made to help center the wheel during installation (many are even made of plastic). The lugs/lug nuts and the frictional force they create against the rotor are what supports the vehicle. Just make sure you're using proper tapered-seat lug nuts with the wheels. </TD></TR></TABLE>
So it shouldnt matter as long as I torque the lug nuts correctly?
&lt;--- Who is trying to avoid broken wheel studs
Old Nov 21, 2004 | 04:16 PM
Padawan's Avatar
Darth ModerVader
As long as you are using the correct tapered-seat lug nuts (stock Honda "acorn" nuts will not properly fit the Rota's tapered seat) and they are torqued to spec, you should have no problems.
Old Nov 21, 2004 | 04:17 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Cool man thanks!
Zorro
Apr 5, 2015 07:38 PM
7rrivera7
Jan 21, 2014 01:28 PM
Ek_Eli
Dec 21, 2011 05:45 AM
jamesc2123
Dec 7, 2007 07:21 AM
JCracer723
Mar 17, 2007 05:48 PM
