Black Widow II
Old Nov 20, 2004 | 07:31 PM
iphatcrxi's Avatar
Default Black Widow II
I've searched, but is there a guide or help anywhere to putting this kit on?
Old Nov 20, 2004 | 08:16 PM
speedadiktd's Avatar
Default Re: Black Widow II (iphatcrxi)
yeah! look at your car and go from there. lots of screws and 2 gallons of bondo
Old Nov 20, 2004 | 08:33 PM
Creepshow S60's Avatar
Default Re: Black Widow II (speedadiktd)
ask about body kits in the "appearance" forum of this site, they should know. It's dangerous to ask about body kits in the EF section, as most people despise body kits on their beloved EF chassis Hondas.
Body Kits = Parking Lot Pimpin'
Old Nov 20, 2004 | 09:38 PM
Rostr02's Avatar
Default Re: Black Widow II (y-49CRX)
what about one piece front ends?
Old Nov 20, 2004 | 09:44 PM
I Want An Si's Avatar
ehhh.. Call the manufacturer or a Body Shop!
Old Nov 20, 2004 | 09:51 PM
mrspeaker's Avatar
Default Re: Black Widow II (Rostr02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iphatcrxi &raquo;</TD></TR><TR><TD CLASS="quote">I've searched, but is there a guide or help anywhere to putting this kit on?</TD></TR></TABLE>
Body kits arent my style..Especially the black widow
That kit is fiberglass and doesnt fit as good as a uerathane kit would..
take off your bumpers and put the kit on the car using tape to hold it on..
Chances are you will have gaps everywhere..If you do then take it to a body shop and have it professionally installed for best results...
But if it does fit good and it lines up with everything ,,then use lots of self-tapping screw to hold in place..
As far as the sideskirts...Use screws in the front and back and for the side of the skirt you can use double-sided tape..or have a body shop put in rivets..
You'll probably get tired of the scraping,and cracking of the body kit and end up going back to stock like everyone else..
Make sure this is really what you want to do..
Good luck..
Old Nov 20, 2004 | 11:38 PM
Riceburner247's Avatar
Default Re: Black Widow II (Mrspeaker)
Try ClubSi.com
Come back when you want to learn about actual tech work.
kydoster
28
Feb 19, 2006 06:53 PM
acc97lxAndy
Jan 3, 2004 09:36 PM
XViEtBoiX
32
Jun 8, 2003 08:49 AM
LANEVOIX
Aug 16, 2002 12:32 PM
