Need your help. Car keeps blowing the radio fuse
Old Nov 20, 2004 | 07:28 PM
smithenhiven's Avatar
Default Need your help. Car keeps blowing the radio fuse
I know, that topic title sounds a little funny if your mind is warped, but seriously, I need some help.
I recently changed radios in my 98 civic dx (added a pioneer), and now the 7.5 amp fuse under the hood always blows out as soon as the key is turned on.
I didn't change a single thing other than radios, and the fuse will even blow when I try hooking the stock radio back up.
What the hell is going on here? What should I check? I already checked all my wiring to the pioneer unit, but like I said, now the fuse will blow even when the stock radio is hooked up.
I'm loosing my figgin mind here. Please help.
Old Nov 20, 2004 | 07:54 PM
ATF Kuk's Avatar
Default Re: Need your help. Car keeps blowing the radio fuse (smithenhiven)
u have a short somewhere. u need to check all ur wiring again. make sure that no wires are open to touching metal or any of the other wires. if that doesnt work, let me know.
one more thing, did u use a radio harness?
Old Nov 20, 2004 | 08:01 PM
Default Re: Need your help. Car keeps blowing the radio fuse (ATF Kuk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATF Kuk &raquo;</TD></TR><TR><TD CLASS="quote">u have a short somewhere. u need to check all ur wiring again. make sure that no wires are open to touching metal or any of the other wires. if that doesnt work, let me know.
one more thing, did u use a radio harness?</TD></TR></TABLE>
I'll go over everything again, but I'm 99% sure that the wiring is good. Yes, I used a radio harness that I bougth from Best Buy specifically for my car. It plugs right into the stock radio plug, and I wired the other end to the pioneer harness.
The big problem I'm having is, why when I put my stock radio back in does the fuse continue to blow?
None of the wires are exposed anywhere, yet I have this problem.
Old Nov 21, 2004 | 09:22 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smithenhiven &raquo;</TD></TR><TR><TD CLASS="quote">
None of the wires are exposed anywhere, yet I have this problem. </TD></TR></TABLE>If you used the adpt. harness then somehow the constant power wire has gotten a short in it. Q- does the fuse blow as soon as you plug the fuse in, or as soon as you plug the HUs in, or as soon as you turn on the ign., or not untill you turn the HUs on?
Old Nov 21, 2004 | 12:36 PM
Default Re: Need your help. Car keeps blowing the radio fuse (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">If you used the adpt. harness then somehow the constant power wire has gotten a short in it. Q- does the fuse blow as soon as you plug the fuse in, or as soon as you plug the HUs in, or as soon as you turn on the ign., or not untill you turn the HUs on? </TD></TR></TABLE>
I rechecked all my connections, and everything is fine. I even had my friend with a 97 civic come over so we can see if my radios work in his car, and everything does, so there is not a problem in my wiring of the adapter harness.
The fuse blows as soon as I turn the car to the "on" possition.
Any other suggestions?
Old Nov 21, 2004 | 01:29 PM
fcm's Avatar
fcm
Old Fart
Any other suggestions?</TD></TR></TABLE> Is that with or without the HU plugged in? if with HU plugged in, then I think the adpt. harness is miswired or the harness is mispinned go to http://www.installdr.com to check pinouts. 94
Old Nov 21, 2004 | 01:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Is that with or without the HU plugged in? if with HU plugged in, then I think the adpt. harness is miswired or the harness is mispinned go to http://www.installdr.com to check pinouts. 94</TD></TR></TABLE>
HU is head unit right
The fuse blows out when either the stock radio, or pioneer head unit is plugged in.
I know it's not a problem with the wiring of the adapter harness, because both my stock radio, and pioneer cd player work in my friends car (actually I used my adaptor harness in his car to make the pioneer work)
I haven't checked to see if the fuse blows out even when there is nothing hooked up to the radio harness.
Old Nov 22, 2004 | 03:45 AM
georgelb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smithenhiven &raquo;</TD></TR><TR><TD CLASS="quote">...
I know it's not a problem with the wiring of the adapter harness, because both my stock radio, and pioneer cd player work in my friends car (actually I used my adaptor harness in his car to make the pioneer work)...</TD></TR></TABLE>
You can not rule out the wiring by using the radio in another car. That rules out the radio. And it looks like you ruled out the adaptor harness as well, which only leaves the wiring in your car. I am willing to bet that if you were to plug your friends radio into your car the same thing would happen.
The fuse blows as soon as the key is turned on with the radio connected? Is that right? And both radios and the harness work in your friends car? Is that right? If both are correct, then you have a problem with the wiring in your car somewhere.
You should go ahead and see what happens with nothing hooked to the O.E. harness when you turn the key on, then if nothing happens se what happens with the adaptor harness plugged in but no radio. It is a proccess of elimination.
Old Nov 22, 2004 | 05:00 AM
Default Re: Need your help. Car keeps blowing the radio fuse (georgelb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgelb &raquo;</TD></TR><TR><TD CLASS="quote">The fuse blows as soon as the key is turned on with the radio connected? Is that right? And both radios and the harness work in your friends car? Is that right? If both are correct, then you have a problem with the wiring in your car somewhere.</TD></TR></TABLE>
Yes, that is correct.
How would I start to check the wiring in my car, since that seems to be the only problem?
Old Nov 22, 2004 | 12:43 PM
fcm's Avatar
fcm
Old Fart
How would I start to check the wiring in my car, since that seems to be the only problem?</TD></TR></TABLE> Have you checked yet if the fuse blows without anything plugged into the OEM plug? and you say its the constant power fuse, [7.5 amp] one in the engine bay fuse box that blows, but not untill you turn on the ign., and does it blow on the 1st, 2nd or 3rd key possition? 94
Old Nov 26, 2004 | 09:00 AM
I don't know what the hell was wrong, or why it was blowing fused like that, but now all of a sudden, everything works again, and I didn't change anything, all I did was hooked back up the adapter harness.
Bleakened
Nov 4, 2015 08:13 PM
jodyboy
Jan 5, 2013 08:38 PM
y0ungthr0wed
Dec 17, 2007 03:45 PM
scorpio1472000
Nov 27, 2007 07:15 PM
allmotorej8
Apr 1, 2004 07:06 PM
