Windows Not rolling up
I have a 1992 Honda Accord Lx and when i purchased it, the window would not roll up after i rolled it down. Now the two windows in the back will not roll up and there is like a 1 inch crack between it. Also the window on the drivers side squicks when i roll it down adn i added WD-40 to it but it still squicks. Any ideas why?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Racing9 »</TD></TR><TR><TD CLASS="quote">I have a 1992 Honda Accord Lx and when i purchased it, the window would not roll up after i rolled it down. Now the two windows in the back will not roll up and there is like a 1 inch crack between it. Also the window on the drivers side squicks when i roll it down adn i added WD-40 to it but it still squicks. Any ideas why?</TD></TR></TABLE>
Blew a fuse? (contol prosser in drivers door) loose ground wire. i hate these windows 2 . i have to hold my drivers window tight while rolling up or elce it goes off track and i cant fix it without ripping the dor apart... ******* window seals
most likely that the window master switch is bad, or they came off track, did you tried lowering or rolling up any or all windows from the master switch and each individual door? about the squeak put some silicone spray in the run channels that should take care of it, unless is of track or something else
nfowler
Apr 11, 2017 10:08 PM
Dev1996
Oct 20, 2015 06:28 AM
