B18C1 ObD1 and ObD2 Crank Pulley Questions
Old Nov 20, 2004 | 06:25 PM
TurboTeG4's Avatar
Default B18C1 ObD1 and ObD2 Crank Pulley Questions
http://www.acuraoemparts.com/d...ch=no
Obd1 got 2 plates and small pulley, Obd2 got 1 plate and pulley with gears(#14,15,16) What if you used vise versa say if you had a obd1 and put the obd2 pulley with 1 plate, is there any difference? Also is there just 2 tiny keys holding that assembly in place?
Old Nov 20, 2004 | 06:30 PM
drdisco69's Avatar
Default Re: B18C1 ObD1 and ObD2 Crank Pulley Questions (TurboTeG4)
It won't matter if you use the OBD2 gear with the OBD1 stuff. And there's one tiny key that lines everything up, #19.
Old Nov 20, 2004 | 06:41 PM
TurboTeG4's Avatar
Default Re: B18C1 ObD1 and ObD2 Crank Pulley Questions (drdisco69)
Strange on the OBD2 it has 2 keys while the OBD1 has 1 key, what gives? The keys I have seem a wee bit small
Old Nov 20, 2004 | 06:53 PM
drdisco69's Avatar
If you're using the OBD2 gear, I would use the OBD2 key.
Old Nov 21, 2004 | 09:27 AM
TurboTeG4's Avatar
Yeah but the part number for the key for obd1 and obd2 is the same, says obd1 needs 2 keys and obd2 needs 1 key. I see no reason obd2 needs only 1 key, I dont understand
mobeast808
Jan 26, 2025 09:18 PM
b20_ed
Nov 10, 2005 12:25 PM
stsRacer22
Acura NSX
Jun 23, 2005 08:22 PM
matteg02
Apr 18, 2002 12:27 AM
