Dumb rev-matching question
Old Dec 28, 2001 | 08:15 AM
TypeR01-424's Avatar
New User
Default Dumb rev-matching question
Can rev-matching be bad? I know it sounds dumb but i've been starting to practice doing it downshifting 5-4 and 4-3 under normal conditions. It seems 100% logical but if it were better for the car then why is it not in the manuals or taught in drivers ed? Is it because it's a more "advanced" technique?
Old Dec 28, 2001 | 08:17 AM
yoshi234's Avatar
I shoot brides
Default Re: Dumb rev-matching question (TypeR01-424)
it's alot better on the clutch than letting it slip.
It's probably not taught b/c it's kinda like trying to rub your stomach and pat your head at the same time
Old Dec 28, 2001 | 08:28 AM
New User
Are there any negatives at all? What if done wrong? By the way, is the 3-2 shift harder to rev-match because it is for me.
Old Dec 28, 2001 | 08:35 AM
yoshi234's Avatar
I shoot brides
it's better to err on the reving a little high than t00 low, but really no negatives.
5>4, 4>3, 3>2, 2>1 are all easy to do in my car. It becomes a lot easier after the car is really warmed up though.
Old Dec 28, 2001 | 08:38 AM
AdamITR's Avatar
Default Re: Dumb rev-matching question (yoshi234)
When Road Racing, rev-matching is imperative when downshifting ... so you don't upset the balance of the car when braking for turn-in. Also, it will ensure that you are in the optimum gear when you accelerate out of the turn. Under daily driving situations ... it's not nessecary.
Old Dec 28, 2001 | 10:13 AM
Floyd's Avatar
Default Re: Dumb rev-matching question (AdamITR)
We have drivers in this country that can hardly handle their automatics out on the road.
-Floyd
Old Dec 28, 2001 | 10:22 AM
Batoutahell's Avatar
Many race cars don't have synchro's in the gearbox, so rev matching is necessary. It is a good idea for you to rev match anyway so you don't upset the balance of your car in a turn. Its even better to double-clutch to rev match.
Old Dec 28, 2001 | 10:39 AM
pleiades nutz's Avatar
Default Re: Dumb rev-matching question (Batoutahell)
yeah, what exactly is double clutching. Is it the same as heel to tow??? Am I making any sense at all?
Stumpy's Avatar
Double clutching is when you put the car in neutral, blip throttle, then put it in gear.
How is that, won't double clutching take a bit longer?
[Modified by Stumpy, 2:39 PM 12/28/2001]
Old Dec 28, 2001 | 10:56 AM
BlackAckeR's Avatar
....5>4, 4>3, 3>2, 2>1 are all easy to do in my car. It becomes a lot easier after the car is really warmed up though.
I thought first gear didn't have a synchro, so that (down) shifting into first while moving (2>1) isn't a good idea!?...
Old Dec 28, 2001 | 11:02 AM
Ideal R's Avatar
New User
Default Re: Dumb rev-matching question (BlackAckeR)
I second this.
Even if you are just rolling, you should use 2nd instead of 1st (daily driving at least).
Old Dec 28, 2001 | 11:11 AM
Crossett's Avatar
nope, i do it all the time. 1st definatly has a syncro, reverse doesnt.
Default Re: Dumb rev-matching question (Stumpy)
quote: Double clutching is when you put the car in neutral, blip throttle, then put it in gear.
Is this while upshifting or downshifting? and if you could explain a little better comparing rev matching, heel to tow, and double clutching and when to use what.
If someone could provide this info that would be great! Thanks.
Old Dec 28, 2001 | 11:26 AM
utensil's Avatar
New User
Default Re: Dumb rev-matching question (nighthawkR618)
i cant go 2>1 that easily in my car. i have to be going ilke 1 mph
Old Dec 28, 2001 | 11:39 AM
TypeR 599's Avatar
Default Re: Dumb rev-matching question (ITR #01-1203)
I second this.
yeah, my 1st is pretty though to get back into. every other gear is fine though .
Old Dec 28, 2001 | 11:42 AM
CPR's Avatar
CPR
Default Re: Dumb rev-matching question (utensil)
Actually, I was playing around one time and I was able to get it into 1st from 2nd pretty effortlessly just by giving the accelerator a nice friendly blip.
Old Dec 28, 2001 | 11:51 AM
Sam's Avatar
Sam
Default Re: Dumb rev-matching question (CPR)
Double clutch can be use for both upshift & donwshift
Old Dec 28, 2001 | 12:05 PM
Double clutching is best for downshifting. Let's take an example that you want to shift from 5th to 4th. From 5th gear, you press in the clutch and shift to neutral. Let out the clutch (often forgotten) and blip the throttle. Then, quickly (before the rev's fall) press in the clutch and shift into 4th, then let out the clutch to be in gear. The purpose of double clutching is to get the input shaft spinning the same speed as the output shaft. When you downshift without double clutching, you're only able to match the engine's rev's to the input shaft's rev's. Double clutching is easier on the synchro's. You should have time to double clutch on the track in most hard braking corners.
You can double-clutch for upshifting, but there's not much benefit, and it does take longer to accomplish when you'd rather be hard on the gas.
Heel-toe is the method of blipping the throttle with your foot whileyou're still on the brakes. You really don't use either your heel or toe. This weird term came from the days when race cars had the throttle pedal in-between and lower than the clutch (left) and the brake (right). You would hit the brake with your right toe and blip the throttle with your right heel. Nowadays, the throttle is usually on the right side, so the term heel-toe is kind of antiquated.
Old Dec 28, 2001 | 12:11 PM
Thanks! I needed that, I guess i can pack up an go home for the day now.
Old Dec 28, 2001 | 01:13 PM
Toda Party's Avatar
isn't this rev-matching??
Old Dec 28, 2001 | 01:44 PM
EPGONZALEZ's Avatar
Default Re: Dumb rev-matching question (Toda Party)
double clutching is for transmissions without syncros...
Old Dec 28, 2001 | 09:04 PM
New User
Default Re: Dumb rev-matching question (EPGONZALEZ)
Well I have been blipping the throttle between gears, is that rev-matching or double clutching?
Old Dec 30, 2001 | 02:51 AM
WTypeRogerX's Avatar
How do you rev-match without double clutching?
Old Dec 30, 2001 | 03:08 AM
nevergiveup's Avatar
New User
Default Re: Dumb rev-matching question (CTypeRogerX)
double clutching is when you put it in neutral before you blip and down shift
but rev matching is when you just down shift and blip
double clutching is explained well in the last answer.
also a example remember when you were younger and was on a school bus
if you were watching the driver they must double clutch in order to shift
they need to match the the speed of the engine and the transmittion. (something like that)
but now a days lot of people say double clutching and rev matching are the same
remember gasing while shifting up/down waste gas
i guess thats the only bad thing
but better then burning the clutch all the time
[Modified by nevergiveup, 4:09 AM 12/30/2001]
Old Dec 30, 2001 | 03:12 AM
arren123's Avatar
If you double clutch and rev match you shouldn't have a problem. I can go from 2nd into 1st as when traveling at 30 mph.
I've tried this in a GSR going 10~15 mph and was able to go from 2>1 by using the double clutch - rev match technique.
