95 HONDA PRELUDE
I AM GETTING A HONDA PRELUDE WITH A H23 IT'S AUTOMATIC I WANT TO GET IDEAS
TO SEE WHAT I CAN DO TO IT TO MAKE IT A FAST CAR LIKE USING WHAT KIND OF TURBO KITS WHATTO CHANGE UPGRADE ESU THINGS LIKE THAT DO YOU HAVE ANY IDEA OR PICTURES
1. Use sentences like any other human being.
2. Don't use all caps its difficult to read.
3. Its an auto, unless you really want to make it worth your time get a 5sp or do a 5sp swap, especially if you wish to boost. Automatic's are no fun.
Try this thread:
https://honda-tech.com/zerothread?id=1029795
it is usually at the top for those type of questions
The first thing you should do is make sure the engine is running properly, second you should get a 5 speed swap. third you should do some research using the search function and read as much as you can about engine work and modifications that can be done. https://honda-tech.com/zerosearch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoehouseworker »</TD></TR><TR><TD CLASS="quote">
3. Its an auto, unless you really want to make it worth your time get a 5sp or do a 5sp swap, especially if you wish to boost. Automatic's are no fun.</TD></TR></TABLE>
4. Post a less nebulous title.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type SH »</TD></TR><TR><TD CLASS="quote">The first thing you should do is make sure the engine is running properly, second you should get a 5 speed swap. third you should do some research using the search function and read as much as you can about engine work and modifications that can be done. https://honda-tech.com/zerosearch</TD></TR></TABLE>
nagockakon
Aug 3, 2009 02:02 AM
