how much nitrous can an h22a take?
Old Nov 20, 2004 | 05:13 PM
Tapen00n's Avatar
Default how much nitrous can an h22a take?
i was told 20hp per litre but i was going to put all new internals in low compression and hopefully pull a 100-120 wet shot off.. any help?
Old Nov 20, 2004 | 06:19 PM
ek9jdm's Avatar
Default Re: how much nitrous can an h22a take? (Tapen00n)
how long do you want the motor to last?
Old Nov 20, 2004 | 09:19 PM
BB6-213's Avatar
An eleventy billion shot! work wonders on my car!
Old Nov 20, 2004 | 10:44 PM
beerbongskickass's Avatar
Default Re: (BB6-213)
Well if your putting forged rods/pistons in your H22 you will have ot sleeve the block anyways, so I am guessing you can throw a lot of nitrous into your engine once it's all built. I woldl just turbo the car though if your going to go through all that work to build it up like that. Oh and the stock H22 ringlands are pretty weak, so be careful if your sqeezing on the stock motor.
Old Nov 20, 2004 | 10:47 PM
PrettyLude's Avatar
Default Re: (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">Oh and the stock H22 ringlands are pretty weak, so be careful if your sqeezing on the stock motor.</TD></TR></TABLE>
yes sir, you hit it right on the nail
Old Nov 20, 2004 | 10:51 PM
donkiman's Avatar
if ur rebuilding u shuold definetly turbo it.
Old Nov 21, 2004 | 02:16 AM
Honda_Tengoku's Avatar
people have run 100 shot on stock internals. Jason Whitefield ran a 100 shot on a stock H22 hatch and ran 12.0 consitantly. Just be careful with it. Be conservative on the timing and run good gas. As everyone says the ringlands are very weak, so if u detonate and spike those cylinder pressures your ringlands are sure to go. If u are running a built motor the ringlands are not really an issue. good luck. Personally I would run a 75 shot on stock internals but thats me.
Old Nov 21, 2004 | 02:21 AM
Retired's Avatar
WEST COAST
I have gone 150 shot its last 60 passes then the rings gave way. Thats the Max 11.7 stock motor
projectef
May 27, 2007 11:52 AM
2000r#0283
Feb 2, 2006 10:10 AM
r1de4life
Dec 30, 2005 11:47 AM
Fonzo
Dec 31, 2004 03:00 AM
JDMVTEC
Feb 5, 2004 01:08 PM
