89 CRX SI with JDM B16 and a lot of parts
1.New paint completed this past summer
2.VIS ZC hood
3.Cross Drilled brembo rotors on all four corners
4.Amber Corners
5.Yellow Fogs
6.Spoon Chipped ECU
7.Ground Control Coilovers
8.Tokico Blues
9.Front strut bar
10.JDM B16
11.Place Racing Motor Mounts
12. 4 Puck ACT clutch
13.Cleaannn Engine Bay
14.Tenzo-R 15x6.5 RNR replicas
15.Mastercraft brand new rubber
16. 4-1 DC header
17. Dry Cell Battery
18. Custom Exhaust
19. Short Ram Ebay Intake
20. New timing belt and starter
Only problem is fifth gear grinds and driver side door needs a new seal
$4,000
We extended the wires for the fuse box and put it on the firewall. The headlight harnesses are on the frame rails. The ground wire for the valve cover is on the back side. The sensors on the ffirewall are bolted under the intake manifold. The battery is in the back. I have about 200 hours in the engine bay work alone.
dam that clean
